Old 07-16-2017, 04:21 PM   #1
Mgutierrez1992
Mgutierrez1992's Avatar
Drives: 2014 Scion Frs
U0100, c1294, p0700
Hello,
So i just recently got a rp400 turbo kit with a deaschwerk 300 cc fuel pump, deastchwerks 700cc fuel pump, and flex fuel kit from delicious tuning. I have everything put on the car but it wont start. There are three codes popping up which are a u0100, p0700 and a c1294. I double checked the fuel pump injectors and there was fuel as well as the fuel pump being put on correctly. So its kind of confusing to why it wont start. The ecu is grounded and the flex fuel wiring is good. When the ecutek program is reading it sometimes says there no response from the obd under a section in A/C. Everything else reads. It's an automatic 2014 scion frs. Any help would be appreciated.
Sent from my SM-G935T using Tapatalk
Mgutierrez1992 is offline   Reply With Quote
Old 07-16-2017, 06:08 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Turbo kit, changed the MAP sensor? Have you flashed the new tune onto the ECU?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-16-2017, 08:15 PM   #3
Mgutierrez1992
Yeah i have the omni 4 bar map sensor. I emailed delicious tuning and they said the tune or the map sensor wasnt the problem.
Old 07-17-2017, 09:22 AM   #4
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
following for information.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 07-17-2017, 02:01 PM   #5
FRS Justin
Drives: 2013 Asphalt FRS
message me your number and I can walk you thru it when you have time to work on your car
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-17-2017, 08:39 PM   #6
Mgutierrez1992
It works! I just changed the map sensor and it started
AT trans throwing codes (P0700, P2757, C1294) Brandon562 Engine, Exhaust, Transmission 11 05-15-2023 06:29 AM
Weird Issue u0100 u0122 Riftur Software Tuning 29 02-17-2020 07:09 AM
Need help. Video and codes P2271, P0171, C1201, U0100 voidn0ise Issues | Warranty | Recalls / TSB 8 05-03-2017 05:58 PM
CEL P0301 C1201 and U0100 peachch Issues | Warranty | Recalls / TSB 32 12-21-2013 04:37 PM
C1294/U0100/P0700 Nightbringer Issues | Warranty | Recalls / TSB 0 07-06-2013 08:18 PM
