Old 07-09-2017, 12:22 PM   #1
alchemis
Drives: JDM Toyota 86 GT limited
washing machine rattling sound on WOT
my car had been heavily used most of the time.
either mountain pass drives or circuit drives. pretty much like a track car.
just after one of the track day i have a weird rattling sound on WOT.
i've searched around and it's not the same like others having.
mine happen on all gears 3k rpm to 4k.
like a rock trapped in an empty washing machine. non rhythmic rattle.
i tot it was clutch issue. but why only 3k to 4k. doesn't feel any jerk at all. no CEL. no lack of power, power still strong.
initialy tot i killed the clutch. but then there's no slippage, and only 3k to 4k.
neutral doesn't give the noise either.
any idea ?
alchemis is offline   Reply With Quote
Old 07-09-2017, 01:36 PM   #2
humfrz
Your washing machine is out of balance.
Open the lid, redistribute the clothes and close the lid.
humfrz
Old 07-09-2017, 04:06 PM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
humfrz
You could be right, it seems like that when it goes into its spin cycle over 4000rpm it gets quieter. The counter weights may have worked free.
Old 07-09-2017, 05:26 PM   #4
RJasonKlein
RJasonKlein's Avatar
Did you go off the circuit on the day you were at the track and the noise began? If so, could you have a stone or stones trapped in the aerodynamic underbody panels making a harmonic rattling between 3-4,000 rpms?
RJasonKlein is offline   Reply With Quote
Old 07-09-2017, 05:32 PM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
So WOT only, not at part throttle? Rocks in the body would be a best case, but I don't think that would be very loud.
what mods?
Old 07-09-2017, 06:37 PM   #6
steve99
metallic rattle under high load, could possibly be detonation/knock
log engine parameters and see if your getting knock correction
have you changed fuels lately, maybe its lower quality
Old 07-09-2017, 08:13 PM   #7
alchemis
That's a good joke on the washing machine...
I didn't went off circuit.
Mods were bolt on like header intake ecu manifold spacer.
If it's detonation, why it's not anything more than 4000rpm just wondering.
As for gas, this tank is a mix. Coz when I head to the circuit I have half tank on other brand. Got no choice but to fill with other brand prior entering circuit.
Because my car is almost race spec with high spring rate. I tot bouncing around the car on normal roads and uneven roads could make the stone come out. But it's still there... uneven roads can't even replicate the sound.
Does detonation only happen at 3k or 4k ? I thought detonation generally happen at high rpm?
Old 07-09-2017, 08:13 PM   #8
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
wots a tot?
Scrappydoo is offline   Reply With Quote
Old 07-09-2017, 08:13 PM   #9
alchemis
Yes it's not part throttle. Only wot
Old 07-09-2017, 08:31 PM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
I only had knock in that range till I fixed the tune (nameless header) - so I'd say yeah, it doesn't have to be at the top of the range. Logging is the sure way to know.
Old 07-09-2017, 09:22 PM   #11
RJasonKlein
Have you checked the header for cracks?
Old 07-09-2017, 09:32 PM   #12
alchemis
I guess it's time to slap on the car to the dyno.
Old 07-11-2017, 05:33 AM   #13
alchemis
diagnose result came out.... the mechanic says there's some mini explosion sound happening under the intake manifold. like a mini explosion sound around that area.
i'm guessing it's direct injection seal.
any ideas ??
Old 07-11-2017, 09:25 AM   #14
bababooey
Drives: BRZ SWP Limited -6MT
Originally Posted by Scrappydoo View Post
wots a tot?
= typically on throttle?
Rattling Sound In Neutral tekFRS234 Issues | Warranty | Recalls / TSB 5 07-16-2015 10:23 AM
gearbox rattling sound at high RPM rennlistuser3 Issues | Warranty | Recalls / TSB 9 07-07-2015 06:29 PM
New rattling sound at idle IAmNotTheDriftKing Issues | Warranty | Recalls / TSB 20 10-24-2014 02:33 PM
Metallic Rattling sound past 4k J-Money Issues | Warranty | Recalls / TSB 2 05-05-2014 09:59 AM
So my key FOB was put in the washing machine.... Kayzer Soze BRZ First-Gen (2012+) — General Topics 11 06-07-2013 11:43 AM
