Old 07-05-2017, 10:49 PM   #1
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
A Lesson for Installing A Hyperflash Relay...
Welp, let me begin by saying hello, and welcome to my second (I think?) thread ever. I ordered some diamond switchbacks for my 2015 FRS from 86speed, which worked perfectly fine... along with a dreaded flasher module... lol...
Long story short, I put the LEDs in place of the turn signal bulbs and replaced the flasher module, which I suppose was faulty because nothing I did with the cautions/turn signals worked.
Went to put back the old one and as soon as I hit the caution lights to test if the old flasher worked, I knew I messed up. Suddenly my lighting wouldn't turn off, my headlights wouldn't work, and my car was telling me my high-beams were on (they weren't, the stalk was at the low beam position). Now, after some searching on the forum, I can only think that I've blown my BCM and that I need a new one... yay...
Lesson to be learned: disconnect the battery unlike I did
NAEightySix is offline   Reply With Quote
The Following User Says Thank You to NAEightySix For This Useful Post:
Tcoat (07-05-2017)
Old 07-05-2017, 10:53 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
We are here to prevent that from happening...ever have doubts forum it out.
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
NAEightySix (07-05-2017), Tcoat (07-05-2017)
Old 07-05-2017, 10:54 PM   #3
NAEightySix
Lessons learned lmao... hopefully this isn't too big of a hit
Old 07-06-2017, 06:28 AM   #4
dnieves
Drives: FR-S 10 Series
Sorry to hear. Next step, how do you replace a BCM?
dnieves is offline   Reply With Quote
The Following User Says Thank You to dnieves For This Useful Post:
NAEightySix (07-06-2017)
Old 07-06-2017, 07:05 AM   #5
NAEightySix
I'm not entirely sure for our cars, but I think I'd much rather take it to a shop that knows what they're doing and that can diagnose whether or not that's really the problem
Old 07-06-2017, 10:33 AM   #6
Chaetagnath
Drives: Whiteout FRS
Probably the BCM. However, you may want to check all your fuses carefully. A member on here had a similar issue a while back, even took it to the dealership (who couldn't figure it out) and after a long saga it turned out to be the HAZ fuse which had a nail crack in it. Worth checking at least.
Chaetagnath is offline   Reply With Quote
The Following 2 Users Say Thank You to Chaetagnath For This Useful Post:
HunterGreene (07-06-2017), NAEightySix (07-06-2017)
Old 07-06-2017, 12:53 PM   #7
NAEightySix
Definitely will check the fuses before I blow money on a new BCM, thanks for that!
Old 07-06-2017, 02:25 PM   #8
MJones_RB
MJones_RB's Avatar
Get a fuse tester. Pulling out each individual fuse and checking it is a painful experience, especially when you are straining to look under your dash.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
Old 07-06-2017, 02:48 PM   #9
HunterGreene
Hail Magnet
HunterGreene's Avatar
I had the same problem when i replaced the flasher relay, it was the HAZ fuse. Much cheaper to fix and still works wonderfully.
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
NAEightySix (07-06-2017), Tcoat (07-06-2017)
Old 07-07-2017, 01:24 PM   #10
NAEightySix
So I got it fixed yesterday, was actually a cocktail of blown fuses according to the dude that fixed it for me. He also put Resistors on my switchbacks, so they work perfectly fine now with the LED flasher (makes no sense to me, as I thought the purpose of the LED flasher was to avoid needing to use resistors). Charged 170 buckaroos for resistors + fuse fix.
The Following 3 Users Say Thank You to NAEightySix For This Useful Post:
Chaetagnath (07-08-2017), JoeC (07-07-2017), Tcoat (07-07-2017)
Old 07-07-2017, 01:33 PM   #11
JoeC
Drives: Subaru BRZ Limited
probably money well spent. It always takes me FOREVER to track down electrical issues but that's because I'm an amateur.
JoeC is offline   Reply With Quote
The Following User Says Thank You to JoeC For This Useful Post:
NAEightySix (07-07-2017)
Old 07-07-2017, 01:37 PM   #12
NAEightySix
I feel you on that one man, although installing the Monogram headlights on my car did make me feel like I had some skill when it comes to tapping wires/crimping/soldering and whatnot. I do all the wiring jobs for my friends lmao
JoeC (07-07-2017)
Where to get Pro driving lesson? HeartbeaT91 Northwest 20 02-26-2016 01:04 AM
Hyperflash Module Skyphire Cosmetic Modification (Interior/Exterior/Lighting) 4 07-07-2015 02:56 PM
Need a drift lesson video with GT86 calibrz Scion FR-S / Toyota 86 GT86 General Forum 28 07-18-2014 01:10 PM
English lesson for the day whaap Off-Topic Lounge [WARNING: NO POLITICS] 28 11-25-2013 07:07 PM
Lesson learned ... these cars do NOT like low octane gas rskdsk Scion FR-S / Toyota 86 GT86 General Forum 28 09-27-2013 11:18 AM
