Old 07-06-2015, 11:41 PM   #1
Skyphire
Drives: FRS
Hyperflash Module
So on the 2015 FRS the hyperflash module is in a different location then the one I watched from Diode Dynamics. I couldn't unhook the module from this white clip that it was stuck on, so i just hooked up the hyperflash and left it hanging next to it. Would that be a problem?
Skyphire is offline   Reply With Quote
Old 07-07-2015, 09:36 AM   #2
jonzhuxD
Drives: Ultramarine FR-S
No. You could zip tie it to the old one if you're concerned about it dangling.
jonzhuxD is offline   Reply With Quote
Old 07-07-2015, 09:46 AM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
probably not,
might bang out and make a noise when you hit a bump
that would annoy me, zip tie it to something
Old 07-07-2015, 12:57 PM   #4
kch
Senior Misanthrope
kch's Avatar
Yeah, that thing was a pain in the ass to get out. It took some hard pulls, but I got the old clip out (it was broken in the process). I left the new flasher module hanging. I meant to get a replacement clip, but it hasn't been an issue, so I've left it hanging for several months.
Old 07-07-2015, 01:56 PM   #5
Poodles
Drives: 2015 Series.Blue
Pull the whole assembly from the metal brace and then remove the clip from the flasher module and swap it to the new module.
I wouldn't leave it dangling because of wire strain issues, and having it attached where it should be will make it louder like it's supposed to be.
YMMV
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
Clock module robot Want-To-Buy Requests 0 06-19-2014 06:52 PM
Led DRL Module hayleybeaners Cosmetic Modification (Interior/Exterior/Lighting) 10 02-20-2014 08:56 PM
BRZ/FRS tap to turn module, notFRS Interior Parts (Incl. Lighting) 2 05-01-2013 03:08 AM
FS: TapTurn module KRAZYK Interior Parts (Incl. Lighting) 6 04-25-2013 02:31 PM
