Old 07-04-2017, 05:00 PM   #1
Darkrune
Darkrune's Avatar
Drives: 2017 86
After magna gauge cluster install.
After installing the face, I can't get the needles to stay in the correct positions for my tach and speedometer. Do I have to replace the cluster or is there a trick to help this?
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 07-04-2017, 06:15 PM   #2
stevesnj
stevesnj's Avatar
Pull the needles turn ignition to run reinstall to Zero while in the run position.
My 2016 Build thread
Old 07-04-2017, 06:20 PM   #3
Darkrune
Darkrune's Avatar
Drives: 2017 86
Thanks for the tip!
Old 07-04-2017, 09:59 PM   #4
Darkrune
Darkrune's Avatar
Drives: 2017 86
So the solution turned out to be that the gauges zero when you open the car door. Turning the ignition doesn't zero the gauge. Opening the car door after it sits for ten minutes does. I pulled the needles and then opened the car door. Put the needles back on and all was gravy. 3 hours later...
Edit this is a MY17 86
New Magna Gauge Cluster Face Install FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 9 01-18-2017 10:42 AM
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
Gauge cluster with Oil Temp Gauge Jetbill Interior Parts (Incl. Lighting) 1 10-06-2015 01:41 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
OEM frs cluster gauge Baramzisyan Interior Parts (Incl. Lighting) 0 08-31-2014 02:39 PM
