Old 07-03-2017, 05:05 AM   #1
devtec
Drives: 2015 Subaru BRZ Limited
Where is the idle air control valve on our cars?
Seems like a silly question, since it should be on the throttle body somewhere. But having a hell of a time finding it... Car has the occasional idle dip, so just want to clean the IAC.
Haven't been able to find the IAC in any diagrams or in real life. There's obviously the plastic housing containing the servo motor and TPS riveted to the TB, but don't see where the IAC is.
TIA!
devtec is offline   Reply With Quote
Old 07-03-2017, 09:39 AM   #2
celek
Resident Gear Head
celek's Avatar
throttle body is basically its own IACV it can open more itself to adjust idle via the ECU.
the only other sensors on the manifold if I recall are MAP and Temp sensor.
I have a similar Idle dip I just ignore it
celek is offline   Reply With Quote
Old 07-03-2017, 12:51 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
As above, it doesn't need an IACV due to the DBW nature of the throttle.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-03-2017, 01:35 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I wish it was as simple as turning a screw to adjust idle speed. I'd like to turn mine up too, but I can't tune and won't mess with that.
Old 07-05-2017, 02:54 AM   #5
celek
Resident Gear Head
celek's Avatar
There is a screw I have taken the throttle body apart,(I have pictures in my Ultimate NA build) BUT your ECU will probably burn out the motor trying to lower it.
Or adjust it in the tune
Old 07-05-2017, 02:58 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think that's just a hard stop to keep from jamming the butterfly.
WTB: Camshaft Timing Oil Control Valve Assembly Connector driftking96 Want-To-Buy Requests 8 05-18-2022 07:02 PM
WTB: Oil Control Valve Soliniod Nst7 Want-To-Buy Requests 0 06-13-2017 11:27 PM
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Camshaft timing oil control valve assembly - P0013 smellslikecurry Issues | Warranty | Recalls / TSB 8 11-02-2016 09:53 AM
Deformed VVT-I Oil Control Valve Caused Oil Leak N1rve Issues | Warranty | Recalls / TSB 9 05-06-2016 12:10 AM
