Drives: scion fr-s
torque
anyone know could affect torque cause some days feel like car launch forward other days feel like car die
foot all the floor is usually fast
| The Following 11 Users Say Thank You to strat61caster For This Useful Post: | Braces (07-01-2017), Cole (07-01-2017), Crashdummy (07-01-2017), extrashaky (07-01-2017), fx1mark (07-02-2017), Impureclient (06-30-2017), jubella2 (07-06-2017), KR-S (07-01-2017), lantsalot (07-05-2017), Spuds (07-01-2017), Summerwolf (07-01-2017) |
How do I shift?
Drives: '13 GBS BRZ
The other day my car died when I put her in 5th from stop. I was just trying to beat that minivan that cut me off but it didn't quite work out.
Drives: 2015 FR-S
car die sound bad maybe entered 87 gas octane formula?
strat61caster right, foot all the floor working usually modifications are inside on your engine place? |
Drives: car
Hot car make not run good. Drive on cold day feel better.
| The Following User Says Thank You to radroach For This Useful Post: | RallySport (07-05-2017) |
Drives: 2013 BRZ Sport-tech WRB
Sometimes, the jar is really hard to open and you need to put it under hot water first.
| The Following User Says Thank You to navanodd For This Useful Post: | KR-S (07-01-2017) |
Although written like an old SNL sketch the OP has a valid question.
John, is the car stock? Is there any pattern to when you have issues?
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DriveDriftDogfight86 (07-02-2017), Vic4uf (07-01-2017) |
Sporadic Member
Drives: 2016 Halo FR-S M/T
somedays i feel very alive while other days i ded in bed
#9 | |
Sporadic Member
Do you have any mods whatsoever? For example maybe a tune from Ecutek or OFT? EDIT: Based on your previous threads, are you still having issues with your MAF as well? |
| The Following User Says Thank You to KR-S For This Useful Post: | Tcoat (07-01-2017) |
#10 |
Drives: 17 86
Some helpful responses so far, but is someone who wrote that OP able to comprehend them?
#11 |
86
button control maybe traction
#12 |
Drives: 17 86
Problem Exists Between Pedals And Seat?
| The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post: | DriveDriftDogfight86 (07-02-2017), Vic4uf (07-01-2017) |
#13 |
Wes
I have noticed this on multiple cars and always attributed it to air humidity and temperature. Car runs better in cooler temperature and when it's humid outside. I believe BMW M4 GTS has a water injection system that humidifies the air in the intake (is that how it works?) so I'm guessing it's something like that. Cause yeah, definitely some days it feels like the car has more oomph.
Also I noticed when I drive it AFTER I have already driven it once and it sat for about an hour or so, so the fluids are still warm, it really flies. |
#14 |
Drives: 2014 BRZ sterling silver
May-be it's the loose nut behind the wheel, (good luck finding a wrench to fit it or a Torque spec).
| The Following User Says Thank You to oldgunfan For This Useful Post: | DriveDriftDogfight86 (07-02-2017) |
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
| Torque Pro App | poorsche | Engine, Exhaust, Transmission | 4 | 12-12-2014 05:01 AM |
| Lug Nut Torque | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-30-2014 07:45 PM |
| Torque Pro | sav | AFRICA | 33 | 08-27-2013 07:31 AM |
