Drives: 2016 Scion FRS
ABS and Slip Light
My ABS and Slip Light are constantly on. I tried shutting the car off and turning it back on and they're still on. I'm planning to bring it to the dealership. Only problem is I'm on an oft tune. I currently have the stage 2 uel 91 tune. Should I flash back to stock before bringing it in? Since I have catless headers won't that throw a code?
Sent from my SM-G920R4 using Tapatalk |
Use your OFT or another OBD scanner to see if the car can tell you what's wrong.
If you've messed with the wheels/brakes at all you might have a damaged wheel speed sensor which would cause those lights to come on. |
Señor Member
See if your brake lights work. My friend had the same issue and it was a broken brake light switch under the pedal.
Is there a CEL as well as those lights?
#6 | |
Oh forgot to answer the question! Some dealers may be fine with the tune but I would flash back just in case. Should take a bit before the header throws the code if it does at all.
I also just noticed my alignment is slightly off. Could that cause these lights to come on?
#9 | |
#10 | ||
majorly off? maybe |
#11 | |
#12 | |
I have no idea what would be best in your situation. |
#13 |
I've had those 2 come on for 2 things!
1. My alignment was off (visibly off) and those 2 were on. 2. I had a blown brake fuse, see if your brake lights work! If they don't, replace fuse and ur good. Sent from my iPhone using Tapatalk |
#14 |
Drives: 15 BRZ LTD, 05 FXT
Tell us more about your alignment being off. Is it really screwy? If you have a ton of toe out in the rear it might be enough to constantly be tripping the light.
I'm in the boat that you likely have a damaged sensor, but it's totally possible that an alignment that's really bad could do this. Did you do LCA's without toe arms perhaps?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| CEL and Slip Light DTC P0353 | rocketbunny86 | Issues | Warranty | Recalls / TSB | 7 | 03-23-2016 07:38 PM |
| Engine light/ slip light and P0458 | evo4g63 | Issues | Warranty | Recalls / TSB | 1 | 10-06-2015 02:06 AM |
| CEL and Slip Light | Gums | AUSTRALIA | 10 | 01-15-2013 08:42 PM |
| CEL and slip light? | Rob_g | Issues | Warranty | Recalls / TSB | 2 | 10-03-2012 04:57 PM |
| Slip Indicator Light | erom | BRZ First-Gen (2012+) — General Topics | 17 | 06-10-2012 10:17 PM |
