Old 06-27-2017, 12:35 PM   #1
illxkoncept
Drives: 2016 Scion FRS
ABS and Slip Light
My ABS and Slip Light are constantly on. I tried shutting the car off and turning it back on and they're still on. I'm planning to bring it to the dealership. Only problem is I'm on an oft tune. I currently have the stage 2 uel 91 tune. Should I flash back to stock before bringing it in? Since I have catless headers won't that throw a code?
Sent from my SM-G920R4 using Tapatalk
illxkoncept is offline   Reply With Quote
Old 06-27-2017, 12:56 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Use your OFT or another OBD scanner to see if the car can tell you what's wrong.
If you've messed with the wheels/brakes at all you might have a damaged wheel speed sensor which would cause those lights to come on.
ineedyourdiddly
Old 06-27-2017, 01:05 PM   #3
STV3
Señor Member
STV3's Avatar
See if your brake lights work. My friend had the same issue and it was a broken brake light switch under the pedal.
STV3 is offline   Reply With Quote
Old 06-27-2017, 02:20 PM   #4
Is there a CEL as well as those lights?
Old 06-27-2017, 02:21 PM   #5
illxkoncept
No I'm not getting a CEL
Old 06-27-2017, 02:23 PM   #6
My money is on a wheel sensor then. Although even that could throw a CEL.
Oh forgot to answer the question! Some dealers may be fine with the tune but I would flash back just in case. Should take a bit before the header throws the code if it does at all.
Old 06-27-2017, 02:25 PM   #7
illxkoncept
Is there anyway I could know which one? I tried looking for a fault code with the oft and it came up with nothing
Old 06-27-2017, 02:27 PM   #8
illxkoncept
I also just noticed my alignment is slightly off. Could that cause these lights to come on?
Old 06-27-2017, 02:27 PM   #9
Out of my knowledge base on that one. @steve99 ?
Old 06-27-2017, 02:40 PM   #10
strat61caster
idk if it throws a code for the header I'd bet money the dealer says they can't fix it because of the header code and don't do anything for him... but that's just my pessimism.
slightly off? no
majorly off? maybe
ineedyourdiddly
Old 06-27-2017, 02:55 PM   #11
illxkoncept
slightly off? no
majorly off? maybe
So you think it would be better just to leave the tune on so it doesn't throw a code for the header?
Old 06-27-2017, 02:59 PM   #12
strat61caster
I would swap back to stock tune and header... after inspecting all the fuses, wheel speed sensors, and alignment.
I have no idea what would be best in your situation.
ineedyourdiddly
Old 06-27-2017, 03:04 PM   #13
allowe
allowe's Avatar
I've had those 2 come on for 2 things!
1. My alignment was off (visibly off) and those 2 were on.
2. I had a blown brake fuse, see if your brake lights work! If they don't, replace fuse and ur good.
allowe is offline   Reply With Quote
Old 06-27-2017, 03:06 PM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Tell us more about your alignment being off. Is it really screwy? If you have a ton of toe out in the rear it might be enough to constantly be tripping the light.
I'm in the boat that you likely have a damaged sensor, but it's totally possible that an alignment that's really bad could do this.
Did you do LCA's without toe arms perhaps?
JazzleSAURUS is offline   Reply With Quote
CEL and Slip Light DTC P0353 rocketbunny86 Issues | Warranty | Recalls / TSB 7 03-23-2016 07:38 PM
Engine light/ slip light and P0458 evo4g63 Issues | Warranty | Recalls / TSB 1 10-06-2015 02:06 AM
CEL and Slip Light Gums AUSTRALIA 10 01-15-2013 08:42 PM
CEL and slip light? Rob_g Issues | Warranty | Recalls / TSB 2 10-03-2012 04:57 PM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 10:17 PM
