Old 06-26-2017, 04:38 PM   #1
justinco
justinco's Avatar
Drives: 2022 GR86
QuickJack setup and testing with my BRZ
After years of using jacks and jackstands on my cars, I finally "upgraded" to a more automated unit. I picked up one of these QuickJack car lifts recently and put together a setup video. Of course, I am testing it out on my 2017 BRZ
[ame]http://www.youtube.com/watch?v=V91BcyIiS68[/ame]
justinco is offline   Reply With Quote
Old 06-30-2017, 10:25 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
nice vid. i love mine too. i want to meet that guy holding it by one hand lol
I am little lazy but when you put less air in that tank, it doesnt collapse fully down after car is on ground.
Old 09-05-2017, 02:42 PM   #3
justinco
justinco's Avatar
Drives: 2022 GR86
FYI, I got the Quickjack pinch weld blocks for my BRZ, since well, it has pinch welds at the jack points.
These work much better than the flat blocks I had in the video. Definitely worth it for our cars.
https://www.quickjack.com/accessorie...er-blocks.html
Old 09-05-2017, 03:21 PM   #4
jasonojordan
Drives: 2013 satin white brz limited
I have been considering getting one of these for winter storage of the car. Lift the car up. Remove the wheels and tires slide them under the car and leave the car up for winter storage.
jasonojordan is offline   Reply With Quote
Old 09-05-2017, 05:50 PM   #5
justinco
justinco's Avatar
Drives: 2022 GR86
I would just use jack stands for that, tbh. But, a Quickjack would work for sure.
Old 09-05-2017, 07:58 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
That might be nice for the tires but it's not good for the suspension bushings. They are at rest with the suspension loaded and strained hard when the chassis is lifted.
Just park it.
Old 09-06-2017, 07:35 AM   #7
jasonojordan
Just park it.
Removing the wheels and tires takes all the load off the suspension so only weight on it is the knuckle itself. Hardly enough weight to do any damage to the damper or bushings imo
Old 09-06-2017, 07:37 AM   #8
jasonojordan
In the past that is what I have used. I would use the quick jack more or less just to get it up there and as a place to store the quick jack that is out of the way when not needed for my other 3 cars. When I need it for my other cars I would just slide the jack stands under it while I am using the jack.
Old 09-06-2017, 08:07 AM   #9
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
Just park it.
Agreed:
When storing my vehicles I inflate the tires to the max listed on the sidewall. This helps with flat spotting and makes it easier to move the vehicle if needed. (No need to removes jacks etc). Also ensures your spring/shockers etc are not being stressed for extended periods of time.
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
Old 09-06-2017, 12:48 PM   #10
Ultramaroon
not playing cards
I'm not talking about weight, I'm talking about the angle of the unloaded control arms and links. All those bushings will sit torqued for months. It's like storing rubber bands in the fully stretched position.
Old 09-06-2017, 01:24 PM   #11
jasonojordan
Gotcha. Well I shall have to do some more research then before this winter. I have stored it both ways in my 4 years of owning the car so far so good.
Old 09-06-2017, 02:31 PM   #12
Ultramaroon
not playing cards
Yeah, I'm not saying it's the end of the world. Just something to consider.
Old 09-06-2017, 03:56 PM   #13
It is best to not leave the suspension dangling even with the weight reduced. It is not designed to be unsprung for long periods. If anything you can take the wheels off and place some blocks under the hubs to hold the suspension where it belongs but not have the whole car's weight on it.
Old 09-21-2017, 12:39 AM   #14
Takumidesh
Takumidesh's Avatar
Drives: 2013 FR-S, 2015 TC
Originally Posted by Darth Khan View Post
Agreed:
it was my understanding that you don't want to keep air in the tires for long term storage and that it was better to get the car off the ground and support the hubs? I may be wrong as I have not really had to store cars for a long time.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY
KANSAI DORIFTO
Takumidesh is offline   Reply With Quote
FS: (MA) Bendpak QuickJack BL3500 Portable Lift gutbomb Mechanical Maintenance and Tools 9 07-25-2021 11:12 PM
Bendpak QuickJack BL-5000 cnk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 104 05-22-2017 06:21 PM
Exhaust setup and noise testing? What DB is yours? Rich196 Engine, Exhaust, Transmission 3 08-31-2016 06:11 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
