| DIY (Do-It-Yourself) Guides For all DIYs. |
btr.life
Drives: 2022 GR86
QuickJack setup and testing with my BRZ
After years of using jacks and jackstands on my cars, I finally "upgraded" to a more automated unit. I picked up one of these QuickJack car lifts recently and put together a setup video. Of course, I am testing it out on my 2017 BRZ
[ame]http://www.youtube.com/watch?v=V91BcyIiS68[/ame]
#2 |
Drives: SWP BRZ
nice vid. i love mine too. i want to meet that guy holding it by one hand lol
I am little lazy but when you put less air in that tank, it doesnt collapse fully down after car is on ground. |
#3 |
btr.life
Drives: 2022 GR86
FYI, I got the Quickjack pinch weld blocks for my BRZ, since well, it has pinch welds at the jack points.
These work much better than the flat blocks I had in the video. Definitely worth it for our cars. https://www.quickjack.com/accessorie...er-blocks.html
#4 |
Drives: 2013 satin white brz limited
I have been considering getting one of these for winter storage of the car. Lift the car up. Remove the wheels and tires slide them under the car and leave the car up for winter storage.
#5 |
btr.life
Drives: 2022 GR86
I would just use jack stands for that, tbh. But, a Quickjack would work for sure.
#6 | |
Just park it.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jcw99 (07-07-2018) |
#7 |
Removing the wheels and tires takes all the load off the suspension so only weight on it is the knuckle itself. Hardly enough weight to do any damage to the damper or bushings imo
#8 |
In the past that is what I have used. I would use the quick jack more or less just to get it up there and as a place to store the quick jack that is out of the way when not needed for my other 3 cars. When I need it for my other cars I would just slide the jack stands under it while I am using the jack.
#9 | |
I think therefore.....
Drives: Toyota 86 860 Halo White (Manual)
When storing my vehicles I inflate the tires to the max listed on the sidewall. This helps with flat spotting and makes it easier to move the vehicle if needed. (No need to removes jacks etc). Also ensures your spring/shockers etc are not being stressed for extended periods of time.
May the N.A. force be with you.
| The Following User Says Thank You to Darth Khan For This Useful Post: | Ultramaroon (09-06-2017) |
#10 |
I'm not talking about weight, I'm talking about the angle of the unloaded control arms and links. All those bushings will sit torqued for months. It's like storing rubber bands in the fully stretched position.
#11 |
Gotcha. Well I shall have to do some more research then before this winter. I have stored it both ways in my 4 years of owning the car so far so good.
#12 |
Yeah, I'm not saying it's the end of the world. Just something to consider.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jasonojordan (09-06-2017) |
#13 |
It is best to not leave the suspension dangling even with the weight reduced. It is not designed to be unsprung for long periods. If anything you can take the wheels off and place some blocks under the hubs to hold the suspension where it belongs but not have the whole car's weight on it.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | jasonojordan (09-06-2017), Ultramaroon (09-06-2017) |
#14 | |
Drives: 2013 FR-S, 2015 TC
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY KANSAI DORIFTO |
| FS: (MA) Bendpak QuickJack BL3500 Portable Lift | gutbomb | Mechanical Maintenance and Tools | 9 | 07-25-2021 11:12 PM |
| Bendpak QuickJack BL-5000 | cnk | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 104 | 05-22-2017 06:21 PM |
| Exhaust setup and noise testing? What DB is yours? | Rich196 | Engine, Exhaust, Transmission | 3 | 08-31-2016 06:11 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
