Old 06-13-2017, 08:25 PM   #1
DR_brz
Drives: lighting red BRZ
Slip light with CEL for mass air flow
So as the title says I've got a slip with the mass air code (forgot number at the moment). Replaced MAF, also new motor...fresh rebuild out of a frs. So new motor is in and runs fine just have lights stuck on. And I'm aware of the massive thread for the bigger issue and pretty sure it's not that.
So BRZ took a swim in a massive puddle (long dumb story here), rebuild of a junked FA and it's in. New plugs (get them from Toyota they are cheaper for the same exact thing) runs just like a brand new 86. But lights are still there. Any possible connection between the 02s and the mass air light? Any insight would be awesome!
DR_brz is offline   Reply With Quote
Old 06-13-2017, 09:00 PM   #2
steve99
Read out any cel codes see what they are
If you want to reset all control modules remove battery terminal for 5 minutes
Abs slip traction light can be triggered due many things but wheel speed sensor issues or if somone messed with steering wheel and centre position needs resetting different rolling diameter tyres sre common ones
Old 06-13-2017, 09:08 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
LOL, I knew @steve99 would wake up any minute.
Old 06-14-2017, 10:19 AM   #4
DR_brz
Have p0102 mass air circuit low, p0117 coolant temp sensor 1 circuit low (this one is new to this situation), p0113 IAT circuit high. Any possible connection between fuel injection ecu and these?
May sound/look stupid but i promise im not car retarded lol
Old 06-14-2017, 05:52 PM   #5
steve99
The maf sensor has an intergrated iat sensor so it looks like maf\iat is suspect or the wiring to it is suspect, do you have a maf extension harness some guys had trouble with the conbections on those.
Coolant temp sensor is different sensor again check wiring and you can likely do resistance check on sensor.
Yes make sure the direct injection computer is well grounded using all mounting bolts it can cause some weird issues but usually with fueling not iat or maf.
Fueling issues or bad not connected maf can cause reich\lean conditions which will trip possibly those type of codes or the ecu may think their is an o2 sensor issue
If the car has been under water then your likely to get all sorts of weird electrical issues due corrosin clean connectors with electricala cleaner\lubricant
Check fuses as well they may be corroded and although not blown may be high resistance their may be a common power source
Here is link to wiring diagram if that helps
http://www.ft86club.com/files/BRZwiringi.pdf
Old 06-14-2017, 09:46 PM   #6
DR_brz
So broke down and called the dealer ship, between the Chrysler guys I work with and the subie dealer the fuel injection Ecu seems to be step two, but luckily I have a spare engine harness just incase (while extra engine minus crank halfs and internals since the internals became externals)
Thanks for the diangram I'll dig into it at work tomorrow while I get paid to do it lol
Old 06-20-2017, 07:16 AM   #7
DR_brz
So belt snapped and took the harness for the MAF with it, replaced harness and all issues gone. Glad I went through two belts to find out the harness was bad
mass air flow sensor John27 Scion FR-S / Toyota 86 GT86 General Forum 4 04-22-2017 11:39 AM
wtb mass air flow sensor 86socal Want-To-Buy Requests 2 03-21-2017 08:03 PM
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 03:57 AM
Mass Air Flow (MAF) delete w/ OFT? PitViper Software Tuning 17 08-10-2015 04:36 PM
WTB a Mass Air Flow sensor AlCo Canada Classifieds 1 12-03-2014 10:19 AM
