Old 06-07-2017, 07:36 PM   #1
Kris86
Kris86's Avatar
Drives: RHD Gt86
Anyone running 9:0.1 compression ?
I'd like to know what the map sensor vacuum reading is at idle on a engine with a similar set up as mine.
I'm using CP pistons 9:0.1 compression with stock cams
I'm getting between .48 ~ .52 BAR
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 06-11-2017, 03:40 AM   #2
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Have a look here >>>>> http://www.gregsengine.com/using-a-vacuum-gauge.html
Convert .48 to .52 BAR to inches of mercury. You're currently around 14 to 15 HG which is below what you want. Could indicate vacuum leak or ring issues.
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
Kris86 (06-11-2017)
Old 06-11-2017, 03:45 PM   #3
Kris86
Kris86's Avatar
Drives: RHD Gt86
I've done a smoke pressurize leak down test and cannot find any
We changed the rings and regapped them thinking it could be that also, nothing changed
Compression test numbers? Anyone done running comp test? Crunk81us Engine, Exhaust, Transmission 2 11-10-2017 01:35 PM
compression ratio nexusatm Forced Induction 38 05-13-2016 07:59 AM
KW V3: 16 clicks for compression? h3opama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2015 08:01 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
