Old 07-12-2016, 05:40 PM   #1
Crunk81us
Drives: Toyota 86
Compression test numbers? Anyone done running comp test?
Did compression test the other day.
I got 165-175 across the 4 cylinders cranking
and around the 210-220 running.
Whats the go with the high numbers running? I thought it was supposed to test between 50-80% of the cranking number?
Also what numbers have you guys been getting? Ive searched and only found one other fa20 test..
Crunk81us is offline   Reply With Quote
Old 11-10-2017, 12:59 AM   #2
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
How many miles do you got on your car?
Also, which places do a compression test without pulling the engine? Or which compression tests devices fit in that small space to test without pulling the engine?
BaBaFlyingSheep is offline   Reply With Quote
Old 11-10-2017, 01:35 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You don't have to pull the engine to do a compression test, it's about the same as replacing spark plugs.
If a mechanic wants to pull the engine to run this test you should find another mechanic.
The Following User Says Thank You to mav1178 For This Useful Post:
toast (11-10-2017)
Compression Test Values - Factory Specifications? kharn83 Engine, Exhaust, Transmission 14 11-13-2017 02:21 AM
Works stage 2 carb comp test socal turtlefeeder Scion FR-S / Toyota 86 GT86 General Forum 1 07-09-2016 02:23 AM
Hey guys I recently test drove the 86 straight after test driving the Megane RS. Obsessionz Scion FR-S / Toyota 86 GT86 General Forum 32 09-23-2014 01:20 PM
is running a test pipe illegal in ontario wilson0326 CANADA 7 09-18-2013 08:32 PM
P&L Header Dyno and Fitment test-With my Vortech Test Kit Huehuecoyotl Engine, Exhaust, Transmission 118 07-07-2013 10:26 PM
