Old 05-26-2017, 11:26 PM   #1
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Tapping/Knocking Sound from Front Coilovers
I installed Ohlins R&T Coilovers about two years and 30k miles ago on my stock swaybars and endlinks. The product has been fantastic, but while going downhill and then sharply uphill at an intersection, I started to hear a tapping/knocking sound from the suspension. The lower control arm of the front is slightly scratched, so I'm wondering if I compressed the spring too much or if over time the car has settled to the point where the stock endlink is too long for the recommended ride height that Ohlins gives you (-20mm front/-15mm rear).
It's not that the top hat moved or alignment changed significantly, right? What should I have a shop look at?
Trefoil is offline   Reply With Quote
Old 06-19-2017, 11:25 PM   #2
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
Not to bump this post from the dead, but it sounds like your stock endlinks are hitting the front lower control arm. I think that's a pretty common issue.
Jidonsu is offline   Reply With Quote
SOLVED: Is this 2013 Scion FRS Engine Knocking/Tapping normal? N1rve Issues | Warranty | Recalls / TSB 215 08-24-2019 03:04 PM
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 10:59 AM
Engine tapping sound HondaCBR08RR Issues | Warranty | Recalls / TSB 17 10-15-2016 06:16 PM
Clutch Clicking/ Tapping sound nooserbtf Issues | Warranty | Recalls / TSB 3 05-04-2016 06:18 PM
Tapping sound above 70 mph Fugazi BRZ First-Gen (2012+) — General Topics 24 10-20-2015 05:04 AM
