Drives: 2013 MT Asphalt FR-S
Anybody encountered issues getting gas in their car? The problem started about a year ago but seemed to be related to the gas pump used. Some pumps worked without issue, others would not work unless I slowly filled the tank.
Fast forward about 9 months and the issue got much worse. No pump would work without stopping the pump several times during a fill-up. I am not using my twin as frequently now, due to moving to the country and purchasing a pickup. This means I am only filling up maybe once a month. The last two times I filled up, it was close to 30 minutes fighting with the pump just to get gas in the car. I have taken the car in for service and have been told that it is the Charcoal Canister that is the problem. I have less than 50K miles on my 2013 FR-S so this seems to be an odd diagnosis to me. What are everyone else's thoughts? |
#2 | |
Edit - That was easy: http://www.ft86club.com/forums/showthread.php?t=54445 http://www.ft86club.com/forums/showthread.php?t=61043 http://www.ft86club.com/forums/showthread.php?t=59616
It sounds like a problem with the gas tank venting, I've never had that problem in a vehicle, put I suppose too much pressure build-up could shut off the gas pump?
Just looked, lots of stuff on youtube about this problem... |
#4 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#5 | |
#6 | |
Drives: 2014 FR-S Asphalt
I have this problem at certain gas stations. It seems some gas nozzles with the spring around them will be just the right size to block the hole in the tank, and I think it triggers the pump to think the tank is full. At my local Costco, I have to make sure I don't put the nozzle all the way in. I back it about maybe a 1/4 in.
#8 | |
After the problem got worse, I pulled the nozzle out a little more and ended up with gas all over my shoes. It is a very fine line so learn from me and don't pull out the nozzle more than the 1/4 inch. |
Drives: JRSC'd Asphalt FR-S
same here its gotten pretty bad for me too.. 2013 frs
been reading old threads, but idk how i should go about fixing it.. lol im sure stealership will charge stealership price since im at like 60k miles |
#10 | |
Noob
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Learning how to pull out properly always takes practice! 😉 Sent from my iPad using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599 -1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black |
#11 |
And coincidentally enough improper pulling out can result in an issue after 9 months.
#12 | |
Drives: 2
#13 |
Huge E85 fan!
Drives: 2016 Scion FRS
@5hairpins do you ever top off when you gas up? Has the nozzle ever failed to click off on its own and spilled out? It only takes one time. Even once can cause probs with the evap system and the canister. What you describe is the classic symptoms.
If you are not getting a CEL [yet] then you can either live with the PITA of filling up (it'll get worse) or just fix it. It tends to be expensive although I don't know how it is for this car. |
#14 | |
Drives: blue
But i had this issue with one of my cars and the solution will get even more puns, i use to just put the tip in about an inch or two and half click the gas nozzle so its not on full blast but this requires your attention at the pump because you will need to hold the nuzzle. And let the puns begin
| Slight hesitation after filling 'er up | stranger things | Issues | Warranty | Recalls / TSB | 5 | 05-21-2017 08:09 PM |
| Filling out the low-end | buzznasa | Electronics | Audio | NAV | Infotainment | 20 | 03-31-2014 01:21 AM |
| Fuel overflowing when filling... | TRBO2NR | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 09-13-2013 09:56 PM |
| Filling holes in front grill? | Fast_Freddy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 06-20-2013 11:44 AM |
| I was planning on just filling out paperwork... | Longhorn248 | BRZ First-Gen (2012+) — General Topics | 34 | 06-05-2012 07:31 PM |
