Old 05-26-2017, 11:11 AM   #1
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Exclamation Problem filling car with gas
Anybody encountered issues getting gas in their car? The problem started about a year ago but seemed to be related to the gas pump used. Some pumps worked without issue, others would not work unless I slowly filled the tank.
Fast forward about 9 months and the issue got much worse. No pump would work without stopping the pump several times during a fill-up. I am not using my twin as frequently now, due to moving to the country and purchasing a pickup. This means I am only filling up maybe once a month. The last two times I filled up, it was close to 30 minutes fighting with the pump just to get gas in the car.
I have taken the car in for service and have been told that it is the Charcoal Canister that is the problem. I have less than 50K miles on my 2013 FR-S so this seems to be an odd diagnosis to me. What are everyone else's thoughts?
5hairpins is offline   Reply With Quote
Old 05-26-2017, 11:16 AM   #2
There was a history of the rubber in the fill tube collapsing with some of the early 13s. I will try to dig up the threads for you.
Edit - That was easy:
http://www.ft86club.com/forums/showthread.php?t=54445
http://www.ft86club.com/forums/showthread.php?t=61043
http://www.ft86club.com/forums/showthread.php?t=59616
Old 05-26-2017, 11:17 AM   #3
BRZdart17
It sounds like a problem with the gas tank venting, I've never had that problem in a vehicle, put I suppose too much pressure build-up could shut off the gas pump?
Just looked, lots of stuff on youtube about this problem...
BRZdart17 is offline   Reply With Quote
Old 05-26-2017, 11:18 AM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
My MR2 does this. Charcoal canister was the answer I have found/keep getting but I have just lived with it so far so cant confirm. I would say 50K miles is a bit low for that to be the cause but there are always faulty products
Old 05-26-2017, 12:42 PM   #5
5hairpins
5hairpins's Avatar
Unfortunately my fill tube is not the issue, they ran a camera down it and it was not collapsed. The tech was quite surprised when I asked and mentioned the early 13's (mine is 738) have had this issue. He also mentioned that there is an active TSB for the fill tube. Thanks for the threads, I tried searching but none of those threads popped up in my search.
Old 05-26-2017, 12:51 PM   #6
Well if that has been ruled out then it is probably the canister just as the tech said. Seems odd it would happen with so few miles but god only knows what could have got caught up in it. Like the damned spiders in propane fittings! Why the hell do they like it in there so much?
Old 05-26-2017, 01:20 PM   #7
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
I have this problem at certain gas stations. It seems some gas nozzles with the spring around them will be just the right size to block the hole in the tank, and I think it triggers the pump to think the tank is full. At my local Costco, I have to make sure I don't put the nozzle all the way in. I back it about maybe a 1/4 in.
Vampyre is offline   Reply With Quote
Old 05-26-2017, 02:14 PM   #8
5hairpins
5hairpins's Avatar
For the first 9 months of the issue, backing out the nozzle a bit usually worked.
After the problem got worse, I pulled the nozzle out a little more and ended up with gas all over my shoes. It is a very fine line so learn from me and don't pull out the nozzle more than the 1/4 inch.
Old 05-26-2017, 11:39 PM   #9
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
same here its gotten pretty bad for me too.. 2013 frs
been reading old threads, but idk how i should go about fixing it.. lol im sure stealership will charge stealership price since im at like 60k miles
Old 05-27-2017, 01:43 AM   #10
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Learning how to pull out properly always takes practice! 😉
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
Old 05-27-2017, 02:48 AM   #11
And coincidentally enough improper pulling out can result in an issue after 9 months.
Old 05-28-2017, 08:43 PM   #12
ktBonefish
Drives: 2
A much more expensive one than problems at the fuel pump provide
ktBonefish is offline   Reply With Quote
Old 05-28-2017, 09:17 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
@5hairpins do you ever top off when you gas up? Has the nozzle ever failed to click off on its own and spilled out? It only takes one time. Even once can cause probs with the evap system and the canister. What you describe is the classic symptoms.
If you are not getting a CEL [yet] then you can either live with the PITA of filling up (it'll get worse) or just fix it. It tends to be expensive although I don't know how it is for this car.
guybo is offline   Reply With Quote
Old 05-31-2017, 03:56 PM   #14
ssworks
Drives: blue
At least 18 years more expensive.
But i had this issue with one of my cars and the solution will get even more puns, i use to just put the tip in about an inch or two and half click the gas nozzle so its not on full blast but this requires your attention at the pump because you will need to hold the nuzzle.
And let the puns begin
ssworks is offline   Reply With Quote
Slight hesitation after filling 'er up stranger things Issues | Warranty | Recalls / TSB 5 05-21-2017 08:09 PM
Filling out the low-end buzznasa Electronics | Audio | NAV | Infotainment 20 03-31-2014 01:21 AM
Fuel overflowing when filling... TRBO2NR Scion FR-S / Toyota 86 GT86 General Forum 26 09-13-2013 09:56 PM
Filling holes in front grill? Fast_Freddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-20-2013 11:44 AM
I was planning on just filling out paperwork... Longhorn248 BRZ First-Gen (2012+) — General Topics 34 06-05-2012 07:31 PM
