Old 05-17-2017, 02:28 PM   #1
neilr
Drives: 2018 Cayman, 2013 FR-S
Head gasket failures on unmodified engines?
The latest iteration of the BRZ has me considering getting back into an 86, but...
My wife's 2009 Impreza recently needed to have its head gasket (or is that plural?) replaced. It has, maybe, 80K miles on it. Looking around other Subaru forums and talking with local mechanics, this appears to be a known Subaru problem.
My question: do the 86s also have this issue?
neilr is offline   Reply With Quote
Old 05-17-2017, 02:38 PM   #2
I have read a couple of hundred thousand posts and do not recall ever seeing one single blown head gasket on a stock engine. Different head and block than the ones you have read about.
12foot (06-21-2019), humfrz (05-17-2017), neilr (05-17-2017), Opie (01-06-2020), strat61caster (05-17-2017), tCsonfrs (05-17-2017)
Old 05-17-2017, 02:43 PM   #3
D_Thissen
D_Thissen's Avatar
Two different motors. I believe it's an ej motor in your wife's impreza while the BRZ has an fa motor. Haven't seen any head gasket issues on these cars.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
neilr (05-17-2017), tCsonfrs (05-17-2017)
Old 05-17-2017, 02:47 PM   #4
jasonojordan
Drives: 2013 satin white brz limited
The head gasket issue is not on all ej motors either. They are more common on certain ones then others.
jasonojordan is offline   Reply With Quote
The Following 2 Users Say Thank You to jasonojordan For This Useful Post:
86kahl (04-10-2018), neilr (05-17-2017)
Old 05-17-2017, 04:16 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I personally know a guy whose engine head gasket blew, BUT he was an avid track enthusiast with many track miles, definitely it is not an issue on this FA20 motors.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
neilr (05-18-2017), Tcoat (05-17-2017)
Old 05-17-2017, 05:59 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I am not sure there's large enough of a sample size of cars over 80k miles to answer your question definitively. That said, 80k miles is simply too little miles for the average engine of any kind to experience a head gasket failure.
And yes, in the case of Subaru engines you need head gaskets.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
86kahl (04-10-2018), neilr (05-18-2017)
Old 05-17-2017, 06:21 PM   #7
reeves
I've yet to see a definitive case of a blown head gasket on a non-modified 86 with 80K miles. I've seen plenty of modified 86's driven hard without a blown head gasket.. with 70K miles or more (mine's included).
reeves is offline   Reply With Quote
The Following 3 Users Say Thank You to reeves For This Useful Post:
neilr (05-18-2017), Tcoat (05-17-2017), Wally86 (02-09-2021)
Old 05-17-2017, 08:17 PM   #8
Ragin Gti
Drives: '15 Subaru BRZ
When Subaru switched to the chain driven engine('11 in Forester, maybe '12 in Impreza/Crosstrek) the external head gasket leaks seemed to have stopped. They now leak from other places(randomly, not from abuse or mods) due to using silicone sealer instead of gaskets. Buy one, oil leaks are covered for 60k(Subaru at least, not sure on Toyota warranty).
Ragin Gti is offline   Reply With Quote
The Following User Says Thank You to Ragin Gti For This Useful Post:
neilr (05-18-2017)
Old 05-17-2017, 08:24 PM   #9
extrashaky
Drives: 2014 BRZ Limited
There was one where a guy bought a stock BRZ used with 3000 miles on it and discovered it had a blown head gasket. Of course, there's no telling what was done to it during that 3000 miles before he got it, but the dealership fixed it under warranty.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
Old 05-18-2017, 01:05 PM   #10
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Did your wife's car ever have the coolant replaced? Subaru engines require the Cooling System Conditioner part number SOA635071. Without it, the head gaskets may leak. Just wondering...
sly is offline   Reply With Quote
Old 05-19-2017, 12:45 PM   #11
neilr
I don't know. She pretty much tends to the care and feeding of her car. Do you know when the treatment is required?
Old 05-19-2017, 01:49 PM   #12
mav1178
mav1178's Avatar
Since we are focusing on tiny sample sets, I should point out that my friend's wife's 1999 Impreza RS 2.5 (original owner) has never had engine problems of any kind.
It was also regularly maintained.
The Following User Says Thank You to mav1178 For This Useful Post:
Tcoat (05-19-2017)
Old 05-19-2017, 06:33 PM   #13
sly
sly's Avatar
Anytime the coolant is drained out of the car, Subaru recommends adding their cooling system conditioner when refilling with antifreeze. They put it in there from the factory so unless you have changed your coolant, it should still be in there.
Old 05-19-2017, 06:44 PM   #14
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Does this also apply to the BRZ/FR-S? Link to the product?
ApexEight is offline   Reply With Quote
Head gasket install Andreas83 Engine, Exhaust, Transmission 1 09-07-2016 09:09 PM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 01:08 PM
Head Gasket leak? Carlsson Issues | Warranty | Recalls / TSB 8 10-23-2015 12:49 AM
Blown head gasket?? texasbound972 Engine, Exhaust, Transmission 29 05-19-2015 11:09 AM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 09:45 PM
