Old 05-19-2016, 05:00 AM   #1
sqd
sqd's Avatar
Drives: '13 SWP GT86
Alignment recommendations for my setup?
I just wanted to ask the knowledgeable people around here, if when I get my alignment done in a week, should I just tell them to go with the OEM specs, or go a little more "aggressive" or outside the OEM specs for any of the settings?
I am on adjustable coilovers, LCAs and toe rods. My wheels are 18x9.5 +45 with 265/35 Pilot Sport Cup 2s all around. The car sees 95% street driving, a lot of it is "spirited" country road driving, rest is just city. There will a track day or two, but not more than that.
I think I've heard that a little more camber in the front than the OEM specs is a good idea, but can't remember exactly.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 05-19-2016, 05:20 AM   #2
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Your setup is fairly close to mine. Check this out : http://www.ft86club.com/forums/showp...postcount=2301
In the end I have -2° front camber, no abnormal wear on the tires. The car has superb handling.
The Following User Says Thank You to Guillaume For This Useful Post:
sqd (05-19-2016)
Old 05-19-2016, 05:54 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I'd put negative camber 2-2.5deg front, 1.5-2deg rear. Regarding wear, it's usually toe that wears them down, camber - at way less rates. Speaking about toe, i'd put front 0, and slight toe-in in rear.
The Following User Says Thank You to churchx For This Useful Post:
sqd (05-19-2016)
Old 05-19-2016, 09:20 AM   #4
sqd
sqd's Avatar
Thanks guys, I'll aim for at least -2 in the front and 1-5 in the rear then, thanks!
IG @squareddesign
Old 05-19-2016, 10:28 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
1.5, not till -5 . It's just that most negative camber numbers i've seen posted are usually 0.5-1 less in rear, next thing is most dial in more neg. camber the heavier the track use is, with biggest numbers i usually seen for drifting. As you posted that it's mostly daily driven, imho no need for insane camber unless it's required to not rub for overly wide wheels-tires choice.
Old 05-19-2016, 01:33 PM   #6
sqd
sqd's Avatar
Haha of course, that was just me slipping on the keys it seems
IG @squareddesign
Need Insight on Shop Recommendations - Alignment Ammunition Northwest 19 04-29-2016 02:04 AM
Alignment shop recommendations? (SEA) Koa Northwest 7 02-16-2015 07:18 PM
Alignment Shop Recommendations (San Diego) RMP Tracking / Autocross / HPDE / Drifting 3 07-25-2014 04:14 AM
Recommendations for alignment in Socal anewprelusion Southern California 18 01-13-2014 02:36 PM
Alignment Shop/ tire changing recommendations HATED1 Northwest 4 09-20-2013 05:03 PM
