Old 05-03-2017, 09:03 PM   #1
Impureclient
Drives: 2015 FR-S
New noise after tire alignment
Had alignment done yesterday and now it's making a rubbing sound. The sound is evident driving slowly and turning the wheel even a little but it is louder when fully turned to lock.
This can't be a CV axle could it? It does it turning both ways. What could they have possibly done to make it do this doing an alignment?
The sound starts in at 4 seconds in, happens with each full rotation of the tires.
video:
Edit: Fixed it. I couldn't sit here and stew on it all night til tomorrow having them look it over to see what they did wrong.
So they had the rears on at least 89 ft lbs or better since they didn't move with a torque wrench. That leads me to believe they didn't even touch the rears in the first place for the alignment
since I always use a torque wrench and tighten to 89. The front right was probably 30-40 ft lb tops. The front left was 4 nuts a bit over hand tightened on and I could remove one with no wrench.
So yeah, they could have killed me or made me kill somebody. Does this warrant them to throw it back up on the alignment rack and check it over again since I rode around a good 10 miles like that?
Impureclient is offline   Reply With Quote
Old 05-03-2017, 10:02 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Maybe couldn't hurt just to double check if that could throw off the numbers.
Old 05-03-2017, 10:11 PM   #3
strat61caster
strat61caster's Avatar
Why would they have to touch the rear wheels for an alignment? Everything is accessible without removing the tires.
I'd suspect the front tires won't change the alignment numbers by anything significant, if they'll throw it on the rack for free as an apology sure, but certainly don't pay them to do it.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Cole (05-04-2017), wparsons (05-04-2017)
Old 05-03-2017, 10:11 PM   #4
Gforce
Drives: 2013 Subaru BRZ
You don't normally touch the wheel nuts when doing an alignment.
Gforce is offline   Reply With Quote
The Following 4 Users Say Thank You to Gforce For This Useful Post:
Clipdat (05-04-2017), G-Man (05-04-2017), jasonojordan (05-04-2017), wparsons (05-04-2017)
Old 05-03-2017, 10:35 PM   #5
strat61caster
It makes getting at the front camber bolts a lot easier though, depending on what's in the OP's car it could make sense. Especially if they're following factory instructions for adjusting camber.
ineedyourdiddly
Old 05-04-2017, 12:32 AM   #6
Impureclient
Drives: 2015 FR-S
Yeah, they probably didn't touch the rear. The day before they installed the new tires. When I got home I tightened everything to 89 ftlbs. Then the next day when they did the alignment is when the loosened them again...and didn't tighten them back.
2nd time this happened with them. I don't know if I even want to tell them since then I'll be the "complainer customer". The day before after the tire went on, I also checked the pressure and one tire was filled to 52 psi and the rest 40.
Old 05-04-2017, 09:28 AM   #7
Gforce
Good point. The front wheels would then have to be reinstalled and would not need to be fully torqued just to check the settings. Somebody forgot to tighten?
The Following User Says Thank You to Gforce For This Useful Post:
strat61caster (05-04-2017)
Old 05-04-2017, 09:41 AM   #8
jasonojordan
Drives: 2013 satin white brz limited
Ive never had them remove any of my wheels when my alignment guy has done my alignments...
jasonojordan is offline   Reply With Quote
Old 05-04-2017, 09:45 AM   #9
Tell them but just do it in a polite and respectful manner. If they have a tech that is forgetting to torque or even tighten lug nuts they need to know about it. Doesn't make you a complainer really.
Cole (05-04-2017), strat61caster (05-04-2017)
Rear right tire hopped over curb at low speed. Could this affect alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-05-2016 02:49 PM
Tire Clunking Noise darko Issues | Warranty | Recalls / TSB 5 04-01-2016 02:57 PM
Alignment Shop/ tire changing recommendations HATED1 Northwest 4 09-20-2013 05:03 PM
Tire Noise? Admiral Ballsy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 07-04-2013 09:02 PM
Tire rumble noise Mokiki Issues | Warranty | Recalls / TSB 13 02-13-2013 03:59 PM
