Old 05-04-2016, 09:54 PM   #1
Meanderchap
Drives: Scion FR-S Whiteout 6MT
Rear right tire hopped over curb at low speed. Could this affect alignment?
When exiting a driveway turning right, I idiotically pulled out without realizing that the rear right tire would hop over the curb, probably at 2-3 MPH. Just to clarify, I didn't crash into the curb, I just hopped over it as you see people doing when making right turns out of driveways.
The black plastic panel in the wheel well was partially popped out of place, but I was able to neatly pop it back into place. There is no sidewall bubbling of the tire or damage, as far as I can see without mounting the car up. I recently had my car aligned, do you guys think this would throw it out of alignment? Thanks.
Meanderchap is offline   Reply With Quote
Old 05-05-2016, 12:21 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Should be fine. If your worried, buy a tire tread gauge and check it over a week, compare it to the other side.
The Following User Says Thank You to Mr.ac For This Useful Post:
Meanderchap (05-05-2016)
Old 05-05-2016, 12:58 PM   #3
renfield90
The Stig's German cousin
Unless your tires are very soft and you are racing the car, you will not see appreciable wear in a week.
OP, it's possible but I wouldn't worry too much especially at 2-3mph - the tires/suspension take worse impacts hitting potholes and such.
You could always get some toe plates ($40, less if you make a DIY set) which only tell you what total rear toe is, but will tell you if toe changes over time or if total toe is too much/not enough which would indicate some drift. If the car still drives straight, I really wouldn't worry.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
Meanderchap (05-05-2016), PandaSPUR (05-05-2016)
Old 05-05-2016, 02:34 PM   #4
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
you're fine lol I remember I did that on purpose on my civic.i climbs the curb on one side and pretend it was a monster truck with my gf when the guy in front wouldn't scoot up for my to enter a left turn lane hehe. nothing happen rides like usual.
turtlefeeder is offline   Reply With Quote
The Following User Says Thank You to turtlefeeder For This Useful Post:
Meanderchap (05-06-2016)
Old 05-05-2016, 02:49 PM   #5
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Came to say this.
PandaSPUR is offline   Reply With Quote
Speed Element April special on all labor / maintenance / alignment services! Speed Element Northern California 11 05-01-2015 04:44 PM
Does toe affect camber in the rear? More camber on one side after alignment shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-30-2014 09:37 AM
Will OEM camber bolt install affect alignment B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-23-2014 11:30 PM
How do 2 different pairs of tire affect handling? frslee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-03-2014 02:42 PM
I scraped my rear wheel on curb, can it be fixed? speedy racer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 10-31-2012 12:09 PM
