Old 04-26-2017, 01:40 AM   #1
myioz86
Drives: gt-86 2013
TRACKTION CONTROL @ STABITITY CONTROLL
I am having a problem after putting on new tyres 245/18/40 . At high speed if i wiggle the steering wheel a little,
the stability control light comes on and starts applying brakes. This has never happened before.Is tyre size causing the problem? Old tyres were 235/18/40
myioz86 is offline   Reply With Quote
Old 04-26-2017, 01:55 AM   #2
swarb
Probably need to break in the tires, there is a small layer of oil on them that would reduce traction.
Old 04-26-2017, 02:03 AM   #3
myioz86
Drives: gt-86 2013
thanks, swarb Hope that,s all the problem is . Not a good feeling when you are doing speed and shit starts going on.
Old 04-26-2017, 04:43 PM   #4
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
absolutely not tire size.......
IceFyre13th is offline   Reply With Quote
Old 04-27-2017, 03:11 PM   #5
Vmax911
Drives: WRB BRZ
All 4 tires the same size? New tires will have a slightly larger diameter, and may be mismatched between front and rear.
Vmax911 is offline   Reply With Quote
Old 04-27-2017, 07:22 PM   #6
myioz86
Drives: gt-86 2013
Vmax911 i have 235/40/18 on the front and 245/40/18 on the rear. the rear tires are only 1 week old , front 3years old. Not shore if that would make any difference. will do some burnouts on the weekend and see if i can get that new oil,y stuff off the new tires.
Old 04-27-2017, 09:00 PM   #7
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Your tires dont have the same circonference. The stability control see the wheels not turning at the same speed, and thinks wheels are spinning.
You need to have 4 tires of the same size.
nico_rsx is offline   Reply With Quote
Old 04-29-2017, 12:18 PM   #8
Pekingduck
Drives: 4 wheels
Did you get alignment after? I had similar issue after putting larger tire in the rear and one the rear lower arm were way off.
Pekingduck is offline   Reply With Quote
Old 05-15-2017, 10:21 PM   #9
myioz86
Drives: gt-86 2013
Think it was just the silocone on tyres problem has gone now that i have worn them in a bit.
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 04:58 AM
Cusco rear controll arms fenixv8 Brakes, Suspension, Chassis 3 05-25-2015 02:49 PM
Traction controll problem after steeing wheel install... NickGTI32 Issues | Warranty | Recalls / TSB 9 10-01-2014 03:09 PM
Is the launch controll tune kind of like riding the clutch? Frsexxxy Engine, Exhaust, Transmission 2 04-29-2013 02:21 AM
SoCal car controll clincs / intro to drifting jflogerzi Southern California 16 01-14-2013 08:43 PM
