Old 04-22-2017, 08:24 AM   #1
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Brake fluid change
The book maintenance says to change the brake fluid (flush and fill only I think) at 15k miles. That seems to be a very short interval. Does anyone do this at 15k miles? I asked a service manager at Toyota about this and he shrugged and side to not worry about it
Old 04-22-2017, 09:38 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Depends heavily on how it is used. I'm at 2x in 15k miles... One was after the bbk install, one this spring (where I mostly needed a bleed but messed up...)
Old 04-22-2017, 11:02 AM   #3
stevesnj
stevesnj's Avatar
I'd do it if it says it. If you don't track the car and just daily drive it just flush it with regular fluid otherwise use a higher performance fluid. Flush the clutch slave cylinder while the brakes are being done.
My 2016 Build thread
Old 04-22-2017, 03:53 PM   #4
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
My dealer said it was unnecessary @30K miles.. I asked again at 40K, and was told the same thing. I did it anyway. It's cheap insurance. Might as well do it.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
stevesnj (04-22-2017)
Old 04-22-2017, 05:26 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You can get one of those brake fluid testers. It tests for moisture. That's the enemy of brake fluid -- moisture. If it reads high, then replace it.
If you feel you must replace it, then replace it. It's your peace of mind. I replaced mine at the 2 year mark just for m own peace of mind. I don't track my car and my fluid was still in good condition when I did it.
N1rve
Old 04-24-2017, 09:02 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
x 2
i use brake fluid tester to replace it as well. dont feel like wasting my money and time either. yeah if you feel it must then do it.
Old 04-24-2017, 09:04 PM   #7
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
No need to flush all the fluid, just the fluid in the caliper and some of the line. I bleed my brakes every 15k or so. With two people it takes no time at all.
Ernest72 is offline   Reply With Quote
The Following User Says Thank You to Ernest72 For This Useful Post:
Maverick986 (02-08-2018)
Old 04-25-2017, 08:28 AM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Perfect opportunity to introduce your kids to the 'pump and hold' brake bleeding routine. lol
venturaII is offline   Reply With Quote
Old 04-25-2017, 05:03 PM   #9
zc06_kisstherain
Drives: SWP BRZ
or get bleeder kit. only $20 bux from harbor freight
Old 04-26-2017, 10:16 PM   #10
Gforce
Drives: 2013 Subaru BRZ
Brake fluid is changed by age not mileage. Water absorption is the issue. In humid climates flush all brake fluid every two years regardless of mileage. In dry climates three years is ok.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
ZZT86 (04-27-2017)
Old 08-04-2017, 05:37 PM   #11
e_lunatic
Drives: 2015 Scion FR-S
as has been said, get the tester and test for moisture.
if it's "wet" or very dirty then change it. otherwise I don't worry about it
e_lunatic is offline   Reply With Quote
Old 08-07-2017, 12:55 AM   #12
LudwigMiles
Drives: '13 BRZ
You can get away with original brake fluid for years and years.
Most cars probably never ever change it.
But, if you want to work on your car and be a car guy,
then why not learn to do it for $10?
Good chance to learn something new.
Every 2 years is a decent guideline.
LudwigMiles is offline   Reply With Quote
Old 08-13-2017, 12:34 PM   #13
WNDSRFR
Drives: FR-S,GTI
I've had at least 20 cars in my life and have never changed the brake fluid. I top it of from time to time. But I have never changed it.
I still have a Mk 4 GTI with the original brake fluid in it. It has 265,000 miles on it. And the brakes are as good as the day I bought it new. (The brake pads have been changed a few times.)
Old 08-13-2017, 01:30 PM   #14
WNDSRFR
Drives: FR-S,GTI
Ya know what?
This got me thinking. I just changed the pads on the FR-S a couple weeks ago and I never even opened the hood to check the brake fluid.
I think I'll go do that right now.
AT fluid change when going FI? xsnapshot Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 05-31-2016 07:03 PM
How often do i need to change/bleed brake fluid (DoT 5.1) dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-15-2015 11:50 AM
AT Fluid Change? Estey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-23-2014 09:55 PM
AT Fluid Change Terrapin77 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-29-2013 09:52 PM
DOT4 Brake Fluid Change and ABS Black Tire Tracking / Autocross / HPDE / Drifting 4 04-20-2013 06:24 PM
