Drives: 2017 Asphalt 86
Video of rattle from rear deck
This rattle is awful. I have done three fixes suggested for rear deck rattles.
1. Bent the little post on the drivers side 2. Stuck foam into the holes to tighten the deck lid 3. Pushed on the spots in the TSB and sprayed a bunch of lithium grease. Nothing changed, it's still rattling. Anybody have any ideas? Video below, sorry for crap quality but you can hear it. Problem is, it comes and goes and the day I had an appointment for Toyota service to check it out, the rattle was silent as the grave. Oh, also the rattle is very clearly coming from the passenger side. |
Drives: BRZ Limited; GR86
Best way to address this would be to have someone drive your car and sit so you can pin point where it's coming from. It's hard to believe but a rattle can be coming from a totally different spot but heard at another spot. you can also take out the real deck which should be easier to pin point. I had a similar issue and i sprayed wd40 in between every weld. I also stuck a flat head and lifted every welded spot. as you lift the welded areas you can hear it crack similar to the sound you hear in your video. while your back there, add some sound deadening to the shelf. hope this helps
| Rear Deck Rattle? Fix it in 30s | nzer | DIY (Do-It-Yourself) Guides | 66 | 08-21-2022 01:27 PM |
| Rear Deck Rattle | zuko | Issues | Warranty | Recalls / TSB | 23 | 06-28-2016 10:59 AM |
| Rear Deck Rattle from Sub Install | mynameisnick4 | Electronics | Audio | NAV | Infotainment | 6 | 07-04-2014 03:23 PM |
| Rear deck rattle - fix it in 30s | nzer | AUSTRALIA | 0 | 07-25-2013 04:09 PM |
| do you think the rear deck rattle... | pr086 | Issues | Warranty | Recalls / TSB | 7 | 08-03-2012 04:35 PM |
