Old 04-20-2017, 11:24 PM   #1
Golevka
Golevka's Avatar
Drives: 2015 Subaru BRZ Limited
I want rumble but need advice
Hi everybody,
I have a stock 2015 BRZ with around 15K miles on it.
I want to mod it, mainly to get a deeper rumble sound. Not raspy. Not Godzilla loud.
I love vids I'm seeing of Borla UEL headers. Also love vids of Corsa catback. But I hear combined they are too loud.
Any suggestions for this kind of sound?
Thanks in advance
Golevka is offline   Reply With Quote
Old 04-21-2017, 12:12 AM   #2
ryoma
ryoma's Avatar
UEL headers with stock catback is probably your best bet. see if you like it.
Old 04-21-2017, 12:16 AM   #3
Golevka
Golevka's Avatar
Interesting. Definitely cheaper than replacing the catback too. You may be on to something
Old 04-21-2017, 01:48 AM   #4
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
Off topic, but changing the header will make the check engine light comes on right?
Blue Bird is offline   Reply With Quote
Old 04-21-2017, 02:49 AM   #5
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Anytime you change the flow rate of your exhaust system it could throw off the sensors and the CEL could come on, thus you should also have an appropriate tuned firmware installed.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Blue Bird (04-23-2017)
Old 04-21-2017, 07:14 AM   #6
Ok some advice on a rumble.
Makes sure you chorograph your approach to be intimidating.
Coordinated switchblade operation is vital
You must be able to snap your fingers
Jumping and spinning is vital to properly enter the fray
If looking for exhaust read through this:
http://www.ft86club.com/forums/showthread.php?t=6064
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
DarkSunrise (04-21-2017), e_lunatic (04-21-2017), JD001 (04-21-2017), kakacarrotcake (04-22-2017), ktulu7 (04-21-2017), NowImaBeliever (04-21-2017), ~el~jefe~ (04-21-2017)
Old 04-21-2017, 08:13 AM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Header + OFT stage 2 will solve all of your (lack of) rumble problem and CEL issues.
I have the Gruppe-S header and love it. It sounded great with the stock exhaust. Then just get some exhaust tips (Vibrant 1207) and have them welded on the muffler for $30 and you are done!
BigTuna is offline   Reply With Quote
Old 04-21-2017, 08:57 AM   #8
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
I've got a full exhaust on my car and it's way too loud. That said, I've found that one of the parts that quiets it down the most is the stock front pipe. It's both catted and resonated so it will keep it somewhat quiet.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 04-21-2017, 09:25 AM   #9
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I don't think you'll end up with much rumble (at least nothing you can feel in any way) with the stock catback.
I would retain stock front and overpipe (they cut down on volume and rasp big time), go with a UEL header, and a quieter catback. I found that I couldn't feel any rumble from the Q300 -- You would have to step up to the Perrin 2.5 resonated.
Either way, if at all possible, go jump in some other folks cars. You can read reviews all day and night to try and make a decision... only to put the recommended exhaust on your car and hate it within 5 seconds. It'll save you tons of money to try out as much as you can first.
My 2c: UEL header (gruppe-s, tomei, OFH, etc) with stock front/overpipe and GreddySp-Elite, Perrin 2.5 resonated, or Top Speed Pro-1 (if you can find it). You'll gain rumble that you can feel in the cabin, without much drone (you'll have a little bit on highway... but you can't have rumble at some RPM when cruising, but not at the same RPM on highway).
ajcarson11 is offline   Reply With Quote
Old 04-21-2017, 09:38 AM   #10
NowImaBeliever
Drives: '21 Crosstrek, '96 SVX
Yeah I would start with a header and go from there; I have my eye on the catted UEL header from FT86SPeedFactory and a Motiv overpipe, but I've already done an Invidia N1 CBE and catless resonated front pipe and the car is a bit louder than I prefer, especially on longer drives.
NowImaBeliever is offline   Reply With Quote
Old 04-21-2017, 09:44 AM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Saying all of the above I still don't hear the WRX STI burble.. its so distinctive much like the Harley Davidson beat.
I have a UEL, aftermarket O/P and fast cat front pipe, the rest is stock. The changes removed the torque dip and made some difference to the sound however its not a deep earthy burble/rumble.
Old 04-21-2017, 10:14 AM   #12
ajcarson11
Yeah, exactly. The fun rumble comes from the low-end bass notes under 100hz or so. The stock catback kills notes that are this low in the audio spectrum, so you won't have the sound/feel of rumble.
Old 04-21-2017, 10:18 AM   #13
bababooey
Drives: BRZ SWP Limited -6MT
op, since you didnt say anything about the power bump, try a catback or axleback first searching for the sound. its easier to work on the back than the front (headers). the corsa catback itself sounds great.
Old 04-21-2017, 10:20 AM   #14
Golevka
Golevka's Avatar
Great advice, thanks.
Subie Rumble ejv_frs Engine, Exhaust, Transmission 11 08-01-2016 11:14 PM
exhause rumble gone? ZHoward Engine, Exhaust, Transmission 2 03-16-2016 08:14 AM
BEST EXHAUST FOR RUMBLE edrokone Engine, Exhaust, Transmission 57 01-08-2014 05:34 PM
What is the cheapest possible way to get rumble? KevinTJH Engine, Exhaust, Transmission 22 12-21-2013 03:56 AM
subaru rumble V1B Engine, Exhaust, Transmission 25 07-13-2012 07:03 AM
