Old 04-18-2017, 08:04 AM   #1
btan219
Drives: DGM 15' BRZ Limited
Will staying in a turned off BRZ Limited drain the battery?
Sometimes for my 30min lunch break I'll nap in my car. Would this be draining the battery a little bit if I'm inside the car and it's off? I heard if your fob is 30ft~ from the car they'll sense each other, draining the battery faster.
btan219 is offline   Reply With Quote
Old 04-18-2017, 08:27 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I don't see why it would, don't all the interior lights turn off after a few minutes?
Lol keep doing this and report back if/when it dies.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-18-2017, 09:13 AM   #3
btan219
Unfortunately I don't have an 86/BRZ. Doing some research first
Old 04-18-2017, 09:29 AM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
LOFL!! Why buy a car?? Why don't you get a RV?
Old 04-18-2017, 09:41 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
OP's next car:
Current DD: M235i
Old 04-18-2017, 09:46 AM   #6
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Keep an atltoids box in the car
thomasmryan is offline   Reply With Quote
Old 04-18-2017, 09:47 AM   #7
NickDC88
NickDC88's Avatar
Strange post haha. The battery will be fine.
NickDC88 is offline   Reply With Quote
Old 04-18-2017, 09:47 AM   #8
Do not lay in the car for two or three weeks straight and you will be OK!
Oh, and your car is always using power to broadcast a signal looking for the fob no matter how close you are.
Old 04-18-2017, 11:04 AM   #9
btan219
lmao you guys making it seem like im living in a car. i just nap for lunch break
Old 04-18-2017, 11:21 AM   #10
Old 04-18-2017, 11:32 AM   #11
~el~jefe~
Drives: 2019 MX-5 RF
I enjoy the existence of this post. Highly pleasing.
I imagine he is considering stalking an ex girlfriend in it on a week long stake out. Or maybe bird watching. All appropriate for a car with as much interior space as an Isetta.
~el~jefe~ is offline   Reply With Quote
Old 04-18-2017, 11:44 AM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Looks like a M5...
Old 04-18-2017, 11:48 AM   #13
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
You'll be just fine. I did the same thing for about a year, albeit sometimes with car running and A/C on (no I did not nap while the car was running).
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 04-18-2017, 12:31 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Just needs to check out the thread on survival kit just so the OP is comfortable when living in the car.
Battery Drain from Dash-Rear Cams + Advice? covance Electronics | Audio | NAV | Infotainment 12 04-04-2016 11:08 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Does the bluetooth drain battery even when the car is off? lupindub Scion FR-S / Toyota 86 GT86 General Forum 6 07-30-2015 02:54 PM
Keyless fob and battery drain taiguy BRZ First-Gen (2012+) — General Topics 3 05-01-2015 08:49 PM
BRZ LTD battery drain issue, can't stop open door beep DoomsdayJesus Issues | Warranty | Recalls / TSB 9 02-06-2015 06:05 PM
