Old 04-06-2017, 02:50 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
TOP speed for each gear?
I found this on other website:
"Road & Track, July 2012 issue, pg. 89.
At 7400 rpm the speeds in each gear are respectively:
1: 35 mph (too much commotion in town)
2: 58 mph
3: 83 mph (you could be in trouble)
4: 105 (you're probably going to jail)
5: 127 (do you have a lawyer?)
6: 135 (estimated at 6000 rpm, so I assume it's drag limited)
RPM at 60 mph in top gear: 2700
Hope this helps."
I was doing a pull on the freeway, and I didn't notice that I went over the redline on 2nd gear and it is showing 61mph before I shift to 3rd.
Does any one experience this?
FR-Sky is offline   Reply With Quote
Old 04-06-2017, 02:54 AM   #2
Brayden_23
Drives: Asphalt 2015 FRS
Are you still on stock wheels?
There is also a variance in speedometer readings from car to car
Brayden_23 is offline   Reply With Quote
Old 04-06-2017, 03:03 AM   #3
FR-Sky
FR-Sky's Avatar
I was on aftermarket wheel. I was scare to blow up my engine lol
Old 04-06-2017, 03:32 AM   #4
Gil Scott Heron
Drives: '17 Asphalt 86
My car's too new to drive that hard, and I'm too chill to go to jail.
Gil Scott Heron is offline   Reply With Quote
Old 04-06-2017, 03:51 AM   #5
FR-Sky
FR-Sky's Avatar
I didn't know you can go to jail just because of accelerating into the highway doing 60+ @@
Old 04-06-2017, 03:54 AM   #6
gramicci101
Off Topic
Here you go. Based on the OEM tire diameter. 4th on the auto and 5th on the manual have the same ratios, so they're the same line.
Old 04-06-2017, 09:17 AM   #7
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Being on bigger wheels wouldnt change his speedometer reading anyway. Unless you get speedo adjusted, which almost no one ever bothers to do.
But yea that second part is probably what it is.
PandaSPUR is offline   Reply With Quote
Old 04-06-2017, 09:24 AM   #8
tobin
tobin's Avatar
Drives: '13 BRZ
Just a guess, but since you were over redline (7400 RPM/58 MPH) you were reaching 61 right before fuel cutoff.
tobin is online now   Reply With Quote
Old 04-06-2017, 09:40 AM   #9
Depends on where you are. There are several States where you would indeed go to jail for doing 105 depending on what the speed limit is when you are doing it. Here you could just lose your car and drivers license for a while if you are doing 30 mph over the limit.
Old 04-06-2017, 12:39 PM   #10
Brayden_23
My bad, I got myself a little twisted up. A larger wheel would result in a faster true speed than what is registered on the speedometer. For some reason I was thinking it would result in a different speedo reading when traveling same speed, which I still guess is true, but wouldn't matter when keeping speedo reading constant.
Old 04-06-2017, 03:20 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
I've tripped over that mental brick a couple times.
Old 04-06-2017, 03:30 PM   #12
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
2: 58 mph
Hope this helps."
Does anyone actually go to jail for 105? I could see if you were on a city road but on the freeway people frequently drive close to that speed in Michigan. And if 83 is trouble I'm in trouble every time I drive
Not that I condone dangerous driving, 85 is generally the max I allow myself to go.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 04-06-2017, 04:06 PM   #13
FR-Sky
FR-Sky's Avatar
Yes I felt fuel cut at 61 right before I shift into 3rd gear. Thats when I actually realized I go too far and shift immediately.
Old 04-06-2017, 04:08 PM   #14
FR-Sky
FR-Sky's Avatar
Yea but I wasn't doing crazy speed, I just did a pull on the freeway entrance, I stopped around 70 right after i did a pull on 2nd with speed limit 61.
Thats why I asked does any one experience 2nd gear with 61mph, which i did. cus the max is 58mph for 2nd gear.
Horrible sound while decreasing speed in gear (no clutch) bshep Issues | Warranty | Recalls / TSB 38 08-21-2016 04:53 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Runduce 6-Speed Transmission Gear - 500hp botbs Engine, Exhaust, Transmission 10 11-22-2015 02:59 PM
Stiff 2nd Gear actuation when cold on manual 6 Speed of FRS/BRZ? There's a reason! Moto-P Scion FR-S / Toyota 86 GT86 General Forum 129 09-19-2015 04:49 PM
top speed axleback....or top speed dual catback? pepe Engine, Exhaust, Transmission 10 11-07-2014 07:12 PM
