Drives: 2015 BRZ
Radar detector on back glass
Would a radar detector mounted where my third brake light used to be, work effectively there? The location in the middle of the back glass can "see" through to the front of the car, between the front seats. Thinking about getting a Valentine-1 with the remote display and hiding the main unit there. Could cut holes in the plastic if needed. Should be some easy power wiring nearby too.
Thoughts? Thanks -Mark |
Drives: 15 BRZ LTD, 05 FXT
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Drives: 2013 satin white brz limited
Its possible sure but why?
This is what I did with mine as well as just pulling power off the mirror. https://www.amazon.com/Mirror-Mount-Radar-Detector-Bracket/dp/B0063N7UGA |
#4 | |
Drives: 2015 BRZ
I just don't want anyone to know I have it. I'd like it to be 100% hidden if at all possible. Windshields, mirror and visor mounts still leave it exposed.
If your worried about it being exposed mounting it on the rear window does the same thing so I guess who are you worried about it being exposed to?
If you're that worried, I'd consider mounting it in your grill behind a piece of plexi. It will take some weather proofing, but it's fairly common practice by custom install shops.
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Check the link in my signature, it's not a cheap system.. but definitely stealth, no one will know you have a radar detector
| Radar Detector | UchihaFanBoy | Electronics | Audio | NAV | Infotainment | 23 | 03-26-2015 09:55 AM |
| radar detector? | tYtEn86 | Other Vehicles & General Automotive Discussions | 10 | 08-12-2014 10:32 AM |
| Cop radar detector | poison1916 | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 05-08-2014 12:27 PM |
| WTB Car Radar Detector | FRS_Jack | Want-To-Buy Requests | 0 | 03-17-2014 07:41 PM |
| Radar Detector? | Longhorn248 | Other Vehicles & General Automotive Discussions | 68 | 07-14-2012 04:31 PM |
