Old 04-05-2017, 01:29 PM   #1
LS1M
Drives: 2015 BRZ
Radar detector on back glass
Would a radar detector mounted where my third brake light used to be, work effectively there? The location in the middle of the back glass can "see" through to the front of the car, between the front seats. Thinking about getting a Valentine-1 with the remote display and hiding the main unit there. Could cut holes in the plastic if needed. Should be some easy power wiring nearby too.
Thoughts?
Thanks
-Mark
LS1M is offline   Reply With Quote
Old 04-05-2017, 01:38 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
https://www.radarbusters.com/How-to-...tor-s/2386.htm
JazzleSAURUS is offline   Reply With Quote
Old 04-05-2017, 01:41 PM   #3
jasonojordan
Drives: 2013 satin white brz limited
Its possible sure but why?
This is what I did with mine as well as just pulling power off the mirror.
https://www.amazon.com/Mirror-Mount-Radar-Detector-Bracket/dp/B0063N7UGA
jasonojordan is offline   Reply With Quote
Old 04-05-2017, 01:46 PM   #4
LS1M
Drives: 2015 BRZ
I just don't want anyone to know I have it. I'd like it to be 100% hidden if at all possible. Windshields, mirror and visor mounts still leave it exposed.
Old 04-05-2017, 01:48 PM   #5
jasonojordan
If your worried about it being exposed mounting it on the rear window does the same thing so I guess who are you worried about it being exposed to?
Old 04-05-2017, 01:54 PM   #6
JazzleSAURUS
If you're that worried, I'd consider mounting it in your grill behind a piece of plexi. It will take some weather proofing, but it's fairly common practice by custom install shops.
Old 04-05-2017, 01:59 PM   #7
jasonojordan
http://www.fjrforum.com/forum/index.php?showtopic=9262
Old 04-06-2017, 05:36 PM   #8
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Check the link in my signature, it's not a cheap system.. but definitely stealth, no one will know you have a radar detector
tato.valverde is offline   Reply With Quote
Radar Detector UchihaFanBoy Electronics | Audio | NAV | Infotainment 23 03-26-2015 10:55 AM
radar detector? tYtEn86 Other Vehicles & General Automotive Discussions 10 08-12-2014 11:32 AM
Cop radar detector poison1916 Scion FR-S / Toyota 86 GT86 General Forum 50 05-08-2014 01:27 PM
WTB Car Radar Detector FRS_Jack Want-To-Buy Requests 0 03-17-2014 08:41 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 05:31 PM
