Old 04-01-2017, 12:25 PM   #1
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Replacing Analog Speedometer
Pretend for a moment that you're on team FT86 at Toyota/Subaru, and you've been asked to replace the analog speedo on the dash with something else for the 2018 model year refresh. What would you do?
pushrod is offline   Reply With Quote
Old 04-01-2017, 12:47 PM   #2
Cole
Not a troll
Cole's Avatar
Working oil pressure and temp gauge.
The Following 7 Users Say Thank You to Cole For This Useful Post:
Apoc (04-01-2017), HKz (04-01-2017), kakacarrotcake (04-01-2017), kch (04-04-2017), SC10N (04-08-2017), venturaII (04-05-2017), wireman957 (04-05-2017)
Old 04-01-2017, 01:05 PM   #3
extrashaky
Drives: 2014 BRZ Limited
I would like a real coolant temperature gauge. I run Torque instead and get both coolant and oil temps.
However, after losing an engine I think I understand why the oil pressure gauge wasn't included. When the oil pump failed in mine, the damage was catastrophic, but it happened within seconds. An oil pressure gauge wouldn't have told me anything the idiot light didn't. If this engine gets loose enough as it ages to show low oil pressure on a gauge, I suspect a catastrophic failure will follow too quickly for a gauge to accomplish anything.
These engines seem to have two operating conditions: go or shatter. They're made to run until they don't, and then you throw them away and replace.
The Following User Says Thank You to extrashaky For This Useful Post:
Cole (04-01-2017)
Old 04-01-2017, 01:37 PM   #4
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
A custom configurable digital display that can show any sensor information on the car, can also depict the real status of everything in the traction/stability systems, and has an integrated lap time feature.
I don't ever look left of the tachometer of the dash in this car, the redundant and practically useless analog speedometer render it stupidly useless.
Something a little better and more integrated than what I'm currently using:
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Cole (04-01-2017)
Old 04-01-2017, 02:42 PM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Come on, aftermarket! You could almost stick a small tablet in there and use Torque or something similar.
PetrolioBenzina is offline   Reply With Quote
Old 04-01-2017, 06:05 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Oil temp gauge, since the sensors are already in the engine...
Old 04-05-2017, 01:09 PM   #7
kevman_101
Drives: 2013 Scion FRS
Full Motec system :P with oil temp, pressure, water temp, and customizable for track and such.
kevman_101 is offline   Reply With Quote
Old 04-05-2017, 04:07 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
You could easily fit 3 gauges in it's place, so as mentioned above, oil pressure and temp would be at least two of them.
Glad I'm not the only one who fails to see the point of having a digital speedometer right in the middle of an analog one.
venturaII is offline   Reply With Quote
Old 04-05-2017, 04:15 PM   #9
Someplace there is a write up from Toyota explaining that. Apparently it is a requirement in some countries so we all get both since it reduces the number of special parts required for different regions.
Besides the old guys would just confused by those number flashing by.
Old 04-05-2017, 04:32 PM   #10
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Instead of that wacky rectangular LCD that they put in the 2017s, they should have done what Mazda did and put a circular display in the Speedo area.
My brother just bought a 2016 CX-9 and the display is lovely to look at. Toyota/Subaru could configure it to display all the cool stuff they have in the current model and more.
- The Ancient BRZ Sacrament
by Zaku
Old 04-05-2017, 04:32 PM   #11
mazeroni
Drives: 2013 Scion FR-S Series 10
Why not keep keep everything!?
They could also give us a power gauge.
Edit: sarcasm
mazeroni is offline   Reply With Quote
Old 04-06-2017, 12:26 PM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by mazeroni View Post
Edit: sarcasm
"Mine goes to 1111!"
Tcoat (04-06-2017)
Old 04-06-2017, 12:43 PM   #13
venturaII
venturaII's Avatar
Huh. Does that mean the S2000 wouldn't be sold in those places, since it uses just a digital speedo..?
Old 04-06-2017, 12:59 PM   #14
Beats me. I didn't say it just repeated what I read.
Oil temp gauge instead of analog speedo GT86_PRAGUE Electronics | Audio | NAV | Infotainment 2 12-19-2014 12:50 PM
Replace the Analog speedo...an ideas thread robot Electronics | Audio | NAV | Infotainment 1 11-20-2014 01:28 AM
Analog speedometer theurge Scion FR-S / Toyota 86 GT86 General Forum 16 07-17-2014 06:17 PM
Any analog gamers out there? buzznasa Northern California 23 04-10-2014 07:51 PM
Spliting analog output signal (0-5v) to two inputs. marcoaferrer Software Tuning 16 02-27-2014 10:29 AM
