Old 11-20-2014, 01:32 AM   #1
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Replace the Analog speedo...an ideas thread
In my OBD II gauge thread multiple times people have brought up the idea of what one could put in that often ignored space where the analog speedometer goes. So, I figured I'd start a thread with questions to get the discussion going. Maybe something will come of it, maybe not:
-What would you put there if you could put one gauge in its place? What about two (mirroring the layout of the water temp and fuel gauge on the other side)? I'd be interested in oil temp and probably oil pressure.
-What does a gauge cluster cost (about $200 according to ebay)?
-How would one modify the cluster to look good? The amber (or white) lighting is already in the correct spot.
-How could you screenprint/laser etch/fab the piece you are replacing? I was thinking laser etching would be the easiest to order. Replicating that texture would be a pain in the rear on the FRS. On the BRZ it might be easier.
So, lets hear your thoughts, photoshops, etc.
robot is offline   Reply With Quote
Old 11-20-2014, 02:28 AM   #2
robot
Info gleaned from here: http://www.ft86club.com/forums/showthread.php?t=58207
There should be enough room for multiple small stepper motors in there.
The gauge faces are one large plastic sheet. So you'd want to replicate them plus the modifications on the left side. This would require some precision to get correct, but there are methods for doing this.
NonStopTuning Short Shifter, Info, Ideas, Feedback thread NonStopTuning Engine, Exhaust, Transmission 5 10-23-2014 11:38 PM
Analog speedometer theurge Scion FR-S / Toyota 86 GT86 General Forum 16 07-17-2014 07:17 PM
Any analog gamers out there? buzznasa Northern California 23 04-10-2014 08:51 PM
Ground Control faq/video/picture/ideas thread GC86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 03-29-2014 11:54 AM
*Decals* Greater Vancouver Area Local Decal Ideas Thread DaJo CANADA 112 12-18-2012 08:40 PM
