Old 03-31-2017, 01:59 PM   #1
Tysoncrosby21
Drives: 2017 Asphalt 86
Remove stock front plate bracket?
Ive searched but all the posts I can track down are about aftermarket installs, not removing the bracket.
I got a wrench on the bolt but it just spins in place. Is there something holding it on? Can I just pull the bolt out?
Called the service department and they have no idea what might be holding it, or how to access it.
Tysoncrosby21 is offline   Reply With Quote
Old 03-31-2017, 02:11 PM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
It's a locally installed option depending on where you live.
What's happened for yours won't be common for everyone.
I had to replace my front fascia due to running over a truck retread on the freeway at night.
When I took off the plate mount, they had cut 3/4" holes with a hole saw, then used clipnuts slid onto the side of the hole.
They came off easy, but what a gobbing great eyesore when exposed.
I told the bodyshop "DO NOT DRILL HOLES IN THIS!" and didn't bring the plate mount with the car.
You'll have to do a bit of exploring, possibly with a small mirror and strong flashlight for your application.
Old 03-31-2017, 03:50 PM   #3
SubaruLifer
Drives: 2015 ISM BRZ Premium
Mine has rubber grommets on the back of the screws holding the bracket on. Based on your comments, it sounds like you do too. You need to take off the cover under your engine (the one closest to the front of the car) and hold the grommet in place while you unscrew it.
SubaruLifer is offline   Reply With Quote
The Following User Says Thank You to SubaruLifer For This Useful Post:
Tysoncrosby21 (03-31-2017)
Old 03-31-2017, 04:49 PM   #4
Tysoncrosby21
Sweet,Thanks! Hopefully I can get under there without lifting the car
Old 03-31-2017, 05:49 PM   #5
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
^ this
PandaSPUR is offline   Reply With Quote
Old 03-31-2017, 06:03 PM   #6
Tysoncrosby21
Is the cover under the engine held on by those 5 bolts I can see when I look under there, or is there more holding it
Old 04-03-2017, 09:37 AM   #7
SubaruLifer
Definitely more than 5 bolts. The GrimmSpeed exhaust system/removal DIY has some really detailed pictures/info for removing the plate: http://www.ft86club.com/forums/showthread.php?t=8121
Help Removing Front License Plate Bracket immaculate Cosmetic Modification (Interior/Exterior/Lighting) 23 05-08-2018 05:09 PM
Front License Plate Bracket mervingee BRZ First-Gen (2012+) — General Topics 22 07-03-2014 09:43 AM
OEM Front License Plate bracket installation mwy23 Northwest 13 12-25-2013 04:50 PM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
LOCAL: Stock Front plate bracket for sale Sargy Mid-Atlantic 14 01-14-2013 04:11 PM
