Old 03-29-2017, 07:53 PM   #1
Schace
Drives: 2016 Scion FRS
Angle sensor not functioning​
Okay so I recently installed an after market steering wheel. I did break the spiral cable but I also replaced it with a new. Well after I got everything back together and did the zero point calibrations I still have a steering angle sensor code. I have disconnected it and measured voltage at the connector I am getting voltage there. Next I measured resistance on the ground wire for that circuit but I'm getting 15 ohms and the circuit should have less then 1 ohm at all times. Please help really stumped on this issue.
Sent from my Pixel XL using Tapatalk
Schace is offline   Reply With Quote
Old 03-29-2017, 08:02 PM   #2
humfrz
Well, HELLO, Schace and WELCOME to our forum ........
I'm afraid I can't help you but, I'm sure someone will come along soon.
Meanwhile, there is another thread going where the fellow has some sort of steering wheel problem ...... you might want to check it out.
I hope you get it sorted out.....
(have we come a long way .... , since we would just take the steering wheel off, set the wheels "straight" and put the steering wheel back on the spline (straight) ..... then tighten down the nut and replace the cap. Yep, a 1/2 beer job)
humfrz
Old 03-29-2017, 10:46 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
You're measuring 15 ohms between between pin-1 and a good conductive point on the chassis? Something fishy going on there.
Old 03-29-2017, 10:48 PM   #4
Schace
Yes pin 1 black wire with yellow tracer. But what doesn't make sense is I've never touched that circuit at all so idk what the heck is going on but that steering angle sensor code always comes back immediately no matter what I've tried so far. So stumped lol
Old 03-30-2017, 12:00 AM   #5
Ultramaroon
not playing cards
What code is it?
Old 03-30-2017, 06:22 AM   #6
Schace
C1231
Old 03-30-2017, 11:23 AM   #7
redlined600
redlined600's Avatar
Drives: Fr-s
Are you sure you put the angle sensor on in the correct position?
Old 03-30-2017, 11:34 AM   #8
Did you use Techstream to calibrate?
Old 03-30-2017, 11:45 AM   #9
Schace
Yeah Im sure. Even if I didn't though that still doesn't explain the 15 ohms of resistance I'm getting on the ground wire for that circuit
The Following User Says Thank You to Schace For This Useful Post:
Ultramaroon (03-30-2017)
Old 03-30-2017, 11:45 AM   #10
Schace
Yes I used a tech stream
Tcoat (03-30-2017)
Old 03-30-2017, 01:23 PM   #11
Ultramaroon
not playing cards
C1231
According to the manual you're looking in exactly the right spot. In your shoes, before anything else I'd trace that ground wire to figure out exactly what's going on there.
I'd be scratching my head too but it has to be ruled out. In case you're working with partial info, click on that readme link in my sig.
Old 03-30-2017, 01:31 PM   #12
Schace
Cool. I think I'm gonna cut that c
Ground wire, solder a new wire to and out it at a different ground point and see if that fixes the ground problem. I think it should
Old 03-30-2017, 01:38 PM   #13
Ultramaroon
not playing cards
Nooooo... Trace it first. Find the other end if you can. Seems like something might be pinched. Confirm before doing anything else.
Old 03-30-2017, 01:44 PM   #14
Schace
Well it's spliced behind the head unit and Trac buttons that are on the center console splice into it and the ground is also behind the head unit
C1231 - Steering Angle Sensor STS-V Issues | Warranty | Recalls / TSB 6 01-13-2023 09:13 AM
Need cam angle sensor at autoclub asap D K Tracking / Autocross / HPDE / Drifting 0 05-07-2016 12:11 PM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 06:28 PM
The All New ATI FR-S/BRZ​/FT86 "Triple Meter" G​auge Pod ATIPods Interior Parts (Incl. Lighting) 7 09-18-2014 03:14 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
