Old 03-29-2017, 03:01 PM   #1
Roto88
Drives: White BRZ Limited
Unhappy EPS failure. All indicator lights on. Radio, A/C, Windows,
Update: I turned the car on and i checked the alternator to see how much it was putting out and i got nothing from it. So i disconnected the battery and the car died immediately. Im pretty certain that I have a bad alternator at this point. What do you think?
Original post: as I left work I turned my car on and noticed all my indicator lights on my dash were on. I went to back out and noticed the power steering was out. Upon further inspection I noticed that the radio A/C and Windows weren't working as well. When I got home I checked the fuses in the cab as well as the ones under the hood but none of them were burnt.
I'm currently stationed in Europe, when I left the states I was told that my warranty would be voided. I will take the car in to a service shop this weekend but I was wondering if anyone had a similar experience.
Roto88 is offline   Reply With Quote
Old 03-29-2017, 03:16 PM   #2
humfrz
Nope, no experience like that.
You may wish to check the main fuse (fusible link) and some of the relays.
http://www.ft86club.com/files/BRZwiringi.pdf
humfrz
Old 03-30-2017, 08:31 AM   #3
Roto88
This is what the fuses looks like. It looks like it burnt but it still has a connection could this be the issue and what might have caused this to blow?
Old 03-30-2017, 09:44 AM   #4
Have you done any mods to the car or all stock?
Old 03-30-2017, 10:49 AM   #5
stevesnj
stevesnj's Avatar
Have your alternator checked, an over amp condition from a bad voltage regulator would do this.
My 2016 Build thread
Old 03-30-2017, 12:24 PM   #6
Roto88
Everything is stock. I thought about the alternator just wasn't sure I hope it didn't cause more damage.
Old 03-30-2017, 12:28 PM   #7
Ya an overcharge from a bad regulator or a dead short someplace are the two main suspects. Take a good look around for damaged wires. Not parked someplace where there could be rodents is it? The fuses should have protected everything but the root cause is what needs to be found.
Old 03-30-2017, 12:46 PM   #8
Roto88
Hmm I did look for damaged wires because were I live there are weasels or some rodent that sometimes jump under the hood and like to chew wires but I haven't been able to locate any chewed wires. I'll look again. I do have insurance to protect me if that's the case. If not the problem I'll have to tow it to a shop to get it looked at.
Old 04-01-2017, 04:27 AM   #9
Roto88
Update.
Old 07-10-2017, 01:48 PM   #10
sirsol66
Drives: 2013 FRS- Hot Lava
Update.
Ever figure this out?
sirsol66 is offline   Reply With Quote
WTB, Bespoke radio, OEM headlight and tail lights FRS Justin Want-To-Buy Requests 3 01-29-2016 02:03 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
Does anyone never listen to radio/music and drive with windows down? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 44 08-17-2014 03:09 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 03:38 AM
Clear/Silver indicator lights Afzal AFRICA 16 05-01-2013 04:31 PM
