Drives: 2023 BRZ
How can I keep tires warm while parked outside overnight?
The tires on my car now should not be allowed to go under 32 degrees F. I'm at a hotel tonight, so the car is parked outside. The forecast low is 28.
I need to drive the car at 6:30 tomorrow morning, but it's supposed to drop below 32 degrees around 3:00 a.m. The only thing I can think to do is wake up at 3:00, go drive the shit out of the thing to get the tires, brakes, hubs, etc. as hot as I can, then go back to sleep for a couple hours. Hopefully that would keep them warm enough until I can do it again at 6:30. Can you guys think of any other way I can keep them from getting too cold without having to wake up in the middle of the night? I'm not really looking forward to doing that. I don't really have a place to park it inside for the night. |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My RE71's were on the car when the temps got down to 27 before Dixie and they were ok, but I was able to wait until temps got above freezing before I moved the car.
Can you put the car on jack stands, tires inside overnight? PITA but better than getting up at 3am. |
Drives: 2023 BRZ
Yeah, I have a meeting at 7:15, so I have to move the car by 6:30 at the latest. It'll still be in the 20s at that time.
Drives: 2017 BRZ
I've seen people use bricks when jackstands aren't handy... Though I'm not sure why they leave the lugnuts just sitting there on the street.
There's really no good way without bringing them inside. Unless you have powered heating blankets, or a couple tauntauns you could sacrifice. |
Drives: 2015 CWP BRZ Limited
Bring it inside.
#6 | |
Drives: 2023 BRZ
Drives: 2023 BRZ
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Unless you buy tire warmers probably nothing you can do.waking up in the night just isn't practical. If there is an empty lot near by go there and scrub the tires for a few minutes.
#10 | |
Drives: 2016 FR-S Asphault MT
And lmfao at tauntaun joke
#11 |
Drives: '22 WRB
Scrubbing tires won't keep heat in them remotely long enough to keep them from refreezing. If you're worried about them, swap them out and drive on something else. I wouldn't worry too much about it though. They won't have much grip at those temps, and they may lose some long-term grip, but unless you're competing for an autocross championship, it's nothing to worry about.
Also, hi from a fellow Denver 86'er. |
#12 |
Custom User Title
The subtleness of this joke is unparalleled. Good job sir.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#13 |
In the slipstream
I wouldn't worry about a night or three below freezing. Besides, the temp wasn't below freezing for more than a few hours. If it was several weeks, you would see an issue. My RR's spent the night out, they were fine.
#14 |
Drives: 2013 SWP BRZ Ltd. / E60 M5
Did you end up doing anything? It used to be that tires could not be stored below X temperature. Now, the warnings on some "Extreme" Summer Performance Tires (as Tire Rack calls them) is more specific. This is what they say about Hankook RS4s:
Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle. Flexing of the specialized rubber compounds used in Extreme Performance Summer tires during cold-weather use can result in irreversible compound cracking. While compound cracking is not a warrantable condition because it occurs as the result of improper use or storage, tires exhibiting compound cracking must be replaced.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
| Warm air from vents | blunova | Issues | Warranty | Recalls / TSB | 131 | 10-06-2020 01:27 PM |
| Warm Up? | gt865 | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 09-17-2014 11:28 AM |
| When do you consider the oil warm | sluflyer06 | Engine, Exhaust, Transmission | 14 | 06-26-2014 02:21 PM |
| Greddy Intake System / 5 in Stock / Free Overnight Shipping / Order Now!! | rickspecd | Engine, Exhaust, Bolt-Ons | 11 | 07-12-2013 11:50 AM |
| My "First 86" FR-S Almost Stolen Overnight at Dealership | hgamit | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 12-28-2012 12:54 AM |
