Old 03-24-2017, 09:36 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
How can I keep tires warm while parked outside overnight?
The tires on my car now should not be allowed to go under 32 degrees F. I'm at a hotel tonight, so the car is parked outside. The forecast low is 28.
I need to drive the car at 6:30 tomorrow morning, but it's supposed to drop below 32 degrees around 3:00 a.m. The only thing I can think to do is wake up at 3:00, go drive the shit out of the thing to get the tires, brakes, hubs, etc. as hot as I can, then go back to sleep for a couple hours. Hopefully that would keep them warm enough until I can do it again at 6:30.
Can you guys think of any other way I can keep them from getting too cold without having to wake up in the middle of the night? I'm not really looking forward to doing that. I don't really have a place to park it inside for the night.
Old 03-24-2017, 10:13 PM   #2
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My RE71's were on the car when the temps got down to 27 before Dixie and they were ok, but I was able to wait until temps got above freezing before I moved the car.
Can you put the car on jack stands, tires inside overnight? PITA but better than getting up at 3am.
Twinz is offline   Reply With Quote
Old 03-24-2017, 10:19 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, I have a meeting at 7:15, so I have to move the car by 6:30 at the latest. It'll still be in the 20s at that time.
Old 03-24-2017, 10:42 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
I've seen people use bricks when jackstands aren't handy... Though I'm not sure why they leave the lugnuts just sitting there on the street.
There's really no good way without bringing them inside. Unless you have powered heating blankets, or a couple tauntauns you could sacrifice.
Old 03-24-2017, 10:46 PM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Bring it inside.
jawn is offline   Reply With Quote
Old 03-24-2017, 11:03 PM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
I have another set of wheels and tires I could bolt on inside the car. So I could bring them inside. The problem is doing that would take just as much time as waking up to put heat into the system by driving it hard.
Old 03-24-2017, 11:04 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
Bring it inside.
That's the ideal solution. The problem is I'm in a craphold little town where I don't konw anyone and there's no underground parking garage.
Old 03-25-2017, 10:00 AM   #8
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 03-25-2017, 10:03 AM   #9
stevesnj
stevesnj's Avatar
Unless you buy tire warmers probably nothing you can do.waking up in the night just isn't practical. If there is an empty lot near by go there and scrub the tires for a few minutes.
Old 03-25-2017, 12:47 PM   #10
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
Wouldnt that heat cycling do more damage than leaving them out?
And lmfao at tauntaun joke
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 03-25-2017, 01:51 PM   #11
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Scrubbing tires won't keep heat in them remotely long enough to keep them from refreezing. If you're worried about them, swap them out and drive on something else. I wouldn't worry too much about it though. They won't have much grip at those temps, and they may lose some long-term grip, but unless you're competing for an autocross championship, it's nothing to worry about.
Also, hi from a fellow Denver 86'er.
trippinbillies40 is offline   Reply With Quote
Old 03-26-2017, 03:57 AM   #12
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
The subtleness of this joke is unparalleled. Good job sir.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 03-27-2017, 11:07 PM   #13
Robbie
In the slipstream
I wouldn't worry about a night or three below freezing. Besides, the temp wasn't below freezing for more than a few hours. If it was several weeks, you would see an issue. My RR's spent the night out, they were fine.
Robbie is offline   Reply With Quote
Old 04-24-2017, 10:26 PM   #14
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Did you end up doing anything? It used to be that tires could not be stored below X temperature. Now, the warnings on some "Extreme" Summer Performance Tires (as Tire Rack calls them) is more specific. This is what they say about Hankook RS4s:
Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle.
Flexing of the specialized rubber compounds used in Extreme Performance Summer tires during cold-weather use can result in irreversible compound cracking. While compound cracking is not a warrantable condition because it occurs as the result of improper use or storage, tires exhibiting compound cracking must be replaced.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Warm air from vents blunova Issues | Warranty | Recalls / TSB 131 10-06-2020 01:27 PM
Warm Up? gt865 Scion FR-S / Toyota 86 GT86 General Forum 71 09-17-2014 11:28 AM
When do you consider the oil warm sluflyer06 Engine, Exhaust, Transmission 14 06-26-2014 02:21 PM
Greddy Intake System / 5 in Stock / Free Overnight Shipping / Order Now!! rickspecd Engine, Exhaust, Bolt-Ons 11 07-12-2013 11:50 AM
My "First 86" FR-S Almost Stolen Overnight at Dealership hgamit Scion FR-S / Toyota 86 GT86 General Forum 47 12-28-2012 12:54 AM
