Old 03-17-2017, 02:22 PM   #1
Chimera
Drives: FRS
Dehumidifier?
Anyone use/try a dehumidifier in their car?
I live in the South.. there's lots of water.
I just order an Eva-dry e-500 to give a try, anyone else have comments on this?
Old 03-17-2017, 02:41 PM   #2
humfrz
Well, no.
I live in the PNW and we have lots of water ....... and my car's A/C seems to do a pretty good job of keeping the humidity down.
If you need one of those for your car ....... maybe you should consider moving out of that swamp onto higher ground ....... ?? ......
humfrz
Old 03-17-2017, 03:09 PM   #3
We just freeze it out for 5 months a year.
Cole (03-17-2017), geezerbrzeezer (03-17-2017), roddy (03-17-2017)
Old 03-17-2017, 03:11 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I also live in the humid south, don't ever have a problem with "water" inside, use your A/C more often.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-17-2017, 03:14 PM   #5
Chimera
Drives: FRS
I do avoid using the AC pretty much all the time. I know it comes on automatically in defog mode, but otherwise I don't use it much, and that doesn't do anything when the cars parked.
Old 03-17-2017, 03:19 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
My a/c is on all of the time as it helps to dry the air. Can't stand misted windows!
Old 03-17-2017, 04:50 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
I don't know why but they do seem to collect moisture a lot more than any other car I've owned. Wonder if the HVAC box has a spot that doesn't drain well.
Old 03-17-2017, 04:55 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Have you tried using a dehumidifier??
Old 03-17-2017, 04:58 PM   #9
Ultramaroon
not playing cards
Nah. It's not that bad and I know nothing's actually wrong. Just odd.
Old 03-17-2017, 05:06 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
I usually have side vents open and directed at side windows with the a/c on and experience zero issues with steamy windows.
The Following User Says Thank You to JD001 For This Useful Post:
Ultramaroon (03-18-2017)
Old 03-17-2017, 05:18 PM   #11
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
'100% Renewable, No Cords or Buckets
To renew, just plug the E-500 into a power outlet and let heat gently release the collected moisture. The unit is ready for use again when the crystals turn blue, usually in 12 to 14 hours.'
No cords, yet it gets plugged in to renew...very odd...conflicting statements.
Evidently contains silica gel crystals, which soak up moisture...then it gets plugged into an electrical outlet, contains a heater which dries out the silica gel in time.
Worth a try. Let us know if it handles the job, and how long before it must be plugged in to dry ITSELF out.
ToySub1946 is offline   Reply With Quote
Old 03-17-2017, 05:39 PM   #12
ls1ac
ls1ac's Avatar
I use these units in closed spaces like gun cabinets and they work fine for keeping the humidity low. not intended to remove large amounts of water. a small puddle from the ac is much more than these can handle. and their absorption rate is low and slow.
Old 03-17-2017, 05:42 PM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
Gun cabinets?? How many guns do you have???
Old 03-17-2017, 05:45 PM   #14
radroach
Drives: car
@Chimera I had a hole poked in my floor from running over a chisel on the highway which would cause some ingress and lots of moisture. I had great success in removing wetness and mildew by using Damprid hanging packs hung off the backs of my seats. They'd collect like a liter of water each after about a week.
Also, best place to buy them is Home Depot / Lowes. Everywhere else marks them up like crazy.
The Following User Says Thank You to radroach For This Useful Post:
Chimera (03-18-2017)
