Old 03-16-2017, 09:49 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Twin Disc Clutch Discussion
I have started the process of purchasing forged internals for the car and found even with my current clutch which should be rated for 345 ft/lbs I have started to slip real bad time to time. I'm looking at the Clutch Master Twin Disc part #15738-TD7S-X.
Anyone here able to give me some insight on this?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-17-2017, 12:43 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i had probably 5k miles on mine. make a pedal stop to limit the travel because most twin disks require very little pedal travel. i installed a half inch stop where the factory thin rubber stop is. also buy a velox clutch fork, the stock one will bend. other than that, it feels like a twin disk. it makes noise when the clutch is disengaged, pedal is fairly stiff and it grabs hard. but it wont slip. we have made over 820whp so far on the fx725 on an fa20
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-17-2017, 04:56 PM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Clutch Pedal Travel Stop if you need.
JDKane527 is offline   Reply With Quote
Old 03-17-2017, 05:32 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
ORC also makes quality twin discs.
http://www.paramo.jp/view_pamph20.ph...echnical_13_en
OS Giken as well. a display at SEMA 2016 showcased the differences between pressure plate design that resulted in close-to-stock pedal pressure.
https://www.instagram.com/p/BMRh1CNA...-by=frsport.us
Anyone regret twin disc clutch? Kiske Engine, Exhaust, Transmission 23 11-09-2016 02:23 PM
ACT SB7-HDG6 HD Clutch Kit 6 Puck Sprung Disc No Limit Motorsport Transmission and Driveline 1 03-17-2016 01:26 PM
SOLD!!! EXEDY TWIN DISC Clutch Kit Sportsguy83 Transmission and Driveline 27 10-04-2014 09:06 AM
STi Clutch Disc on FRS/BRZ? Cross Engine, Exhaust, Transmission 3 08-18-2014 04:33 PM
