Old 03-16-2017, 03:18 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Arrow CAN Bus solution database (what works/what doesn't work)
I wanted to make a thread with a list of solutions that are verified and it's known what actually works and what doesn't. It is important to note where you can buy it because for the most part, the solution you buy and the features that work will depend on the supplier off the ECU as in most cases they have needed to write custom code in order to support the stock CAN BUS system.
I will update the OP as more people post.
What Works means, it HAS BEEN VERIFIED WORKING ON A CAR, not "it MIGHT work or it SHOULD work"
Push Start Verified means that the solution has been fully tested on a push button car and it work just like in a regular key car.
Removing dash lights or covering them with tape does not count as "IT WORKS!!"
Please feel free to correct me if there is any misinformation.
Without further ado, (please follow the format as much as possible).
Motec M130
Sold by: Pure Automotive, includes plug and play harness, ECU, license
For what swap: 2JZ AND LS
What works:
Power Steering
Cruise Control
ABS
A/C (regular and dual climate)
Full dash
Stock fuel pump controller works and is controlled via Motec
Custom Traction Control via Motec ECU
Traction control activated/deactivated by the factory traction control button on the shifter trim. Cluster traction lights function along with it.
What does not work:
N/A?
What is expected to get fixed and working on the future:
Push Start car verified: Yes
Source: Pure Automotive
Haltech Elite 2500 done by JR Wiring Solutions
Sold by: JR Wiring Solutions
For what swap: 2JZ
What works:
Power Steering
A/C (works sporadically on the car, sometimes turns off by itself)
Some dash (Fuel gauge is on limp mode, not fully working)
What does not work:
ABS
OEM or aftermarket traction control
Cruise Control
Stock fuel pump controller (needs to be removed)
Push Start car verified: NO
Source: JR Wiring Solutions (This was back in November, things might have changed since then, but not to my knowledge).
Motec M150 Manji in New Zealand
Sold by: One off, not sold by that shop as far as I know
For what swap: 1UZFE VVTI
What works:
Power Steering
Cruise Control
ABS
A/C
Full dash
Custom Traction Control via Motec ECU?
What does not work:
OEM Traction control?
Source: Manji, forum member and car owner
Arduino Custom Controller
Sold by: N/A (forum member wutsaiu personally coded it)
For what swap: LS
What works:
Power Steering
Tachometer
Fuel gauge only 1/4 increments, not fully working
CEL is off (don't know if working)
What does not work:
A/C
Cruise Control
ABS
Water Temperature gauge not working (aftermarket gauge)
Airbag light is on
Source: wutsaiu swap thread.
Emtron KV8 done by Trust Automotive
Sold by: Trust Automotive
For what swap: 2JZ and LS?
What works:
Power Steering
A/C (not verified on Dual Climate)
Most dash (Fuel gauge is on limp mode, not fully working)
What does not work:
ABS
Cruise Control
Stock fuel pump controller (needs to be removed)?
Cruise Control
Source: Trust (This was back in November, things might have changed since then).
MRS CAN Gateway by MRS Electronic
Sold by: MRS Electronic
For what swap: LS
What works:
Power Steering
Coolant Gauge
Fuel Gauge
Fuel Economy
Tachometer
MIL Indication with proper frequency
What does not work:
A/C
ABS
Cruise control
Cruise control
A/C
Source: Colin MRS Electronic (MRS-Colin)
Element Tuning EMS
Sold by: Element Tuning, includes plug and play harness, ECU, license
For what swap: LS3 ONLY
What works:
Power Steering
ABS
Full dash
Custom Traction Control via the EMS
What does not work:
Cruise Control?
Push Start car verified: ??
Source: Element Tuning
Old 03-16-2017, 10:30 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
We have traction control activated/deactivated by the factory traction control button on the shifter trim. Cluster traction lights function along with it. It's just way better traction control firmware than an oem ecu has
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-16-2017, 10:37 PM   #3
Sportsguy83
Drives: Limited BRZ
I'll add it to OP
Old 03-17-2017, 09:31 AM   #4
Bullitt2496
Guest
Posts: n/a
the "fuel pump regulator" is a mechanical device that's part of the pump assembly so I'm not sure what you mean here?
Old 03-17-2017, 09:47 AM   #5
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
I think he means the pump controller.
It's a small device under the panel next to passenger side rear seat.
Stock pump doesn't run at 100% all the time, it can be throttled by the controller. I bypassed the controller so the pump runs 100% at all times.
wutsaiu is offline   Reply With Quote
Old 03-17-2017, 09:57 AM   #6
MRS-Colin
Drives: 2001 Impreza 2.5 RS
For what swap: LS
What works:
Power Steering
Coolant Gauge
Fuel Gauge
Fuel Economy
Tachometer
What does not work:
A/C
ABS
Cruise control
Cruise control
A/C
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 03-17-2017, 10:34 AM   #7
Sportsguy83
Drives: Limited BRZ
Thumbs up
Updated good sir thanks!!!
Old 03-17-2017, 10:37 AM   #8
Sportsguy83
Drives: Limited BRZ
Yes this. I'll update the OP
Old 03-17-2017, 10:37 AM   #9
Bullitt2496
Guest
Posts: n/a
WGP wiring harness bypasses pump controller.
Old 03-19-2017, 02:25 PM   #10
dj2020
The Pure Automotive Motec 130 solution seems the most complete so far. The 2JZ electronics are done and it looks like they're working on a LS application. For those that live in a OBD2 emission state, is there a way to pass emissions though? Please PM me if this is better answered privately.
dj2020 is offline   Reply With Quote
Old 03-19-2017, 05:11 PM   #11
Bullitt2496
Guest
Posts: n/a
Running a standalone is certainly the "best" solution to solve the various electronics challenges... but also costs approx 10x the amount of the others. A Motec M1 is almost 6k for a normal FT86, and then you'll incur addtional costs likely in the thousands for the custom wiring harnesses needed to integrate the engine and body wiring.
Old 03-19-2017, 05:53 PM   #12
spitfire481
Drives: 2JZ FRS
The package includes ecu, license, the swap firmware, wiring harness for engine/body integration, etc
MoTeC
Build Thread
@spitfire481
Old 03-19-2017, 08:05 PM   #13
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Put me on the list for that!...seriously I'm ready for a motec LS kit, what do you need from me, to get on the list?
ILLSMOQ is offline   Reply With Quote
Old 03-19-2017, 09:09 PM   #14
spitfire481
Drives: 2JZ FRS
The ls is still in progress. We got the harness finished last week, just need to finish up the firmware. Race season starts next week, so the shop car is taking all of the tuners attention right now. Should pick back up on the ls package before the end of the month. It is coming along though. We do have an already running ls swapped frs in house we built 2 years ago that is getting the full plug and play package.
MoTeC
Build Thread
@spitfire481
It doesn't work!! Photomikes garage FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 03-06-2017 01:23 AM
Another Backup Cam Doesn't Work Thread ChrisJ Electronics | Audio | NAV | Infotainment 5 07-01-2016 10:09 PM
Error Code, Nav doesn't work slyphen Issues | Warranty | Recalls / TSB 2 12-04-2015 03:37 PM
Installs, Service, Maintanance, Repairs, Custom work, Tuning, Dyno Database! Infamous Performance Mechanical Maintenance and Tools 521 10-30-2015 11:58 AM
USB port doesn't work brianc901 Electronics | Audio | NAV | Infotainment 2 08-15-2014 05:40 PM
