Old 09-16-2014, 05:25 PM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Steering Wheel Adapter Hub Question
For using aftermarket steering wheels, is there a specific adapter hub I should get or would any hub adapter will work? Tried looking throughout the forum but there's nothing about it.
Bach415 is offline   Reply With Quote
Old 09-16-2014, 05:31 PM   #2
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
http://www.86worx.com/daikei-boss-hub-kit.html
sdemo is offline   Reply With Quote
Old 09-16-2014, 05:39 PM   #3
Bach415
Bach415's Avatar
Originally Posted by sdemo View Post
Sorry, but I'm wondering if there needs to be a specific type of hub/hub adapter needed for after market steering wheels. I have an unopened hub adapter from a long time ago but isn't sure if it's made for specific type model because its a discontinued model from like the 90's :P
Old 09-16-2014, 09:37 PM   #4
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Yes you need one made for this car, a generic one may fit but will probably not turn the clock spring which will cause the traction control to not function.
Works bell make an excellent one.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 09-19-2014, 05:40 PM   #5
ShutterSpeed
Drives: Olive Drab/Army FRS
I'd suggest works bell or splash. nrg requires a lot of modification to make it work.
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
FS: (SoCal) 350mm Nardi Gara Steering Wheel, Splash Extended Hub adapter. ix2vi Interior Parts (Incl. Lighting) 11 07-04-2014 12:00 PM
Steering wheel removal question. Dustin Cosmetic Modification (Interior/Exterior/Lighting) 13 03-20-2014 01:32 PM
Key!s Racing steering wheel, quick release and hub adapter (everything you need) troy2003 Interior Parts (Incl. Lighting) 11 02-16-2014 08:25 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Wheel Adapter for VW OEM 5x114mm wheels ongnoi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-12-2013 08:01 PM
