Old 07-14-2012, 09:54 PM   #1
Roborat
Drives: Scion FR-S firestorm red
Adding led Halos as DRLs?
I am new here but I am thinking of adding some led angel eyes/halos when I do my HID retrofit and headlight blackout as soon as I get them in. I was wondering where I can wire in the halos so they function as DRLs? Should I wire them in where the wires run into the resistor? Any impute from someone that knows about this stuff would be great, thanks.
Roborat is offline   Reply With Quote
Old 07-15-2012, 01:23 PM   #2
StevenEngage
StevenEngage's Avatar
Drives: 1995 Nissan Sentra
I would imagine you can just tap into the power for the DRLs that are already there to have both turn on, probably after the resistor like you were saying but I would use an inline fuse for it just in case. Maybe someone else can chime in about it because i am no expert, although that is what I would probably try on my own.
StevenEngage is offline   Reply With Quote
Old 07-15-2012, 01:55 PM   #3
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
TRS sells the halos that fit our car. If you go through them for the retrofit, I'm sure they have detailed instructions.
kmbkk is offline   Reply With Quote
Old 07-15-2012, 02:25 PM   #4
Aznek
Drives: 2013 White Scion FRS
Are they the projector shrouds?
[ame="http://www.youtube.com/watch?v=SiCpc63nmh0&feature=related"]#2 Yamaha R6 Projector Headlights BiXenon hid Angel Eyes Halo By bkmoto projectors - YouTube[/ame] I'm thinking something like this, minus the LED strip.
Aznek is offline   Reply With Quote
Old 07-15-2012, 02:54 PM   #5
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I'd have to go back and check. I contacted them several weeks ago about getting their retrofit kit & halos, and they have some that fit. I believe it is an 80mm LED ring, though, and it fits both the retrofit kit and the stock projectors.
Old 07-15-2012, 03:25 PM   #6
Roborat
The led halos they sell that would fit I believe are the 100mm. They attach to the existing shroud that is already there using either adhesive or last time I used a very thin wire to secure them so u can't see it. I was thinking if they just tied into the headlight wires that would work since it is the headlights that act as the DRLs but at a lower voltage and would also allow them to stay on when the headlights are on as well. Does anyone else have any ideas.
Old 07-15-2012, 06:54 PM   #7
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Moved to Cosmetic Mod forum since this is not a DIY and you will get more answers in this forum.
Adding Subwoofer to stock HU RAN94A AUSTRALIA 49 05-20-2013 07:53 AM
Lamin-X type film for DRLs? Mazdaspeed BRZ First-Gen (2012+) — General Topics 0 06-29-2012 09:48 PM
Adding a sub enclosure yet ? rikdrt1 Electronics | Audio | NAV | Infotainment 10 06-08-2012 09:28 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Adding Navi to the FRS? Pake1 Electronics | Audio | NAV | Infotainment 3 06-01-2012 01:26 PM
