Old 03-11-2017, 01:34 PM   #1
Bushhy
Drives: None
LTFT High, Stock Tune and Stage 1 93
So after running E85 for a little, I decided it was time to go back to 93 because I was taking a long trip, and E85 would be hard to find. I switched back the normal way, and my LTFT seemed a little high, but nothing outrageous, so I kept going.
I am now about 4000 miles past when I switched back, and I cannot get this LTFT and STFT to normalize. I have used the Stock tune, and the 93 Stage 1 OTS tune.
Log on 93 Tune :
http://www.datazap.me/u/bushhy/log-1...1?log=0&data=1
I did a pull. 1st through 3rd. If you look at the LTFT, as soon as I get off the throttle, it jumps to around 15.
Log on Stock Tune :
http://www.datazap.me/u/bushhy/log-1...4?log=0&data=1
Just a couple minutes of normal driving. At one point, I jabbed the throttle and Knock Correction kicked in. I was told the stock tune allows some knock at the higher RPMs
Im thinking it may be an Intake leak? Or maybe an Exhaust leak.
Do these numbers look bad, or should I be fine.
Bushhy is offline   Reply With Quote
high ltft while running e85 with oft flat4_86 Software Tuning 4 01-22-2017 12:47 AM
OFT Stage 2 Tune comparable to stock 02-07 wrx? Mr.Impreza Software Tuning 29 10-15-2015 06:20 PM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 10:27 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 02:52 PM
