Old 03-03-2017, 01:01 PM   #1
Riftur
Riftur's Avatar
17x9 gram light 57xtreme rims
So i just purchased a set of 17x9 gram light 57xtreme rims and was wondering which tire would be the best for it? I live in south florida and its my DD so I need something thats decent on wet roads. Any suggestions would be great. Also if anyone from around ft lauderdale fl knows of a good place to have them mounted I would appreciate it. I am worried a lot of places might scratch them. I used to get my tires from places like tire kingdom, tires plus etc etc. I dont trust them with my expensive arse rims though. They usually hire kids who dont really care and I dont want them screwing up my rims.
Thank in advance,
Riftur is offline   Reply With Quote
Old 03-03-2017, 01:08 PM   #2
Vital
Drives: 2015 BRZ
Thank in advance,
You need a 245/40/17 tire size. Also, if you're lowered you might need to add some camber in the front depending on the offset.
Vital is offline   Reply With Quote
Old 03-03-2017, 01:20 PM   #3
Riftur
Riftur's Avatar
The suspension is stock and the offset is 40mm
Old 03-03-2017, 02:12 PM   #4
Vital
Drives: 2015 BRZ
Yes, you'll most likely rub you might want to get some camber bolts to add some camber up front.
Here is a thread to help you also. http://www.ft86club.com/forums/showthread.php?t=42746
The Following User Says Thank You to Vital For This Useful Post:
Riftur (03-03-2017)
Old 03-03-2017, 03:35 PM   #5
Brayden_23
Drives: Asphalt 2015 FRS
I run the 57Xtreme 18x8.5 and have 235/40s. The wheels actually have a bit of a lip on them so the tire doesn't fit completely flush with the edge of the wheel. I would probably need to go up to a 245. Since you are running a 9 inch wheel, a 245 would work, but a 255 would most likely look the best. You would definitely need to change out for coilovers in the front though so you don't rub.
As for tires that do well in the rain, I run MPSS here in the Pacific Northwest where it is constantly raining. MPSS have a high resistance to hydroplane and have always given me complete confidence, wet or dry.
Brayden_23 is offline   Reply With Quote
Old 03-03-2017, 03:49 PM   #6
Riftur
Riftur's Avatar
The wife is not going to let me spend any more money on the car right now so I have to stick with the stock suspension. Are the MPSS's very soft or will they last a while? I like to slide my car around and don't want to replace them every 20k miles. Thanks for the info.
Old 03-03-2017, 04:56 PM   #7
Brayden_23
Well in that case 245's will have to work. Just know that the wheel will stick out further than the tire.
The MPSS have a 30k mile warranty. I think they are a terrific balance between tread wear and grip.
The Following User Says Thank You to Brayden_23 For This Useful Post:
Riftur (03-03-2017)
Old 03-04-2017, 09:42 AM   #8
gtpvette
Drives: 2015 FRS - FFR GTM
Same size and offset as my 949 Racing Wheels. On stock suspension you should be fine,,, I was. I lowered with RCE Yellow springs and the front was really tight to the spring so I added a 5MM spacer. No problems.
I have 245/40/17 on my 17x9 rims as well. I put BFG's on and they're decent enough but really loud. I wont get another set. I normally look at Discount Tire, Tire Rack and EBAY for best prices. Last two sets were both from EBAY. My experience is most decent tire shops can mount and balance without scratching rims.
http://www.ft86club.com/forums/showt...light=gtpvette
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Riftur (03-04-2017)
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
NORCAL FT/maybe Fs Gram light 57xtreme shaynek Wheels and Tires 11 03-15-2016 12:25 PM
Rays gram light 57xtreme elementskater Wheels and Tires 14 12-05-2015 06:04 PM
WTB Gram Lights 57Xtreme 17x9.0 +40 ngabdala Wheels and Tires 0 06-24-2014 12:52 AM
FS: Gram Light 57Xtreme with Hankook V12 Evo clevrname Wheels and Tires 46 09-06-2013 04:24 PM
