Drives: 2017 Red subaru BRZ Limited
Best OBD2 app for Iphone
I wanted to buy and ODB2 sensor for the 2017 BRZ, but wasn't sure which is the best app to get for the iPhone. Can you guys give your reviews on which app would be the best paid and free. Thanks
Ohne Titel
Drives: 2017 BRZ PP ISM
DashCommand works pretty well. Interface isn't perfect, but once you use the examples to see how to set up custom settings it's alright. Stay away from cheap wi-fi OBD dongles. I had a Veepeak one that bent the pins on my car's OBD port. You might consider using an OBD2 extension and plugging the dongle into that. Some of them have a switch to prevent battery drain: http://amzn.to/2mF6DrX
I'm now using a Bluetooth Kiwi 3, and the update rate with Harry's LapTimer is much faster than wi-fi. It's $99 vs $15 though: http://amzn.to/2lyMxPo |
#3 | |
Drives: 2016 FR-S
Ohne Titel
@burningjello - I got an extension cable, plugged it in to the OBD port, and that solved the problem. I was able to use an EcuTek cable with the extension, as well as 2 different dongles, and everything works fine. Worth a try for $10. This is the cable that worked for me: http://amzn.to/2lXice7
Although if I had to do it again, I like the idea of one with a switch (linked above). |
Drives: 2017 CWP BRZ
I use dash command and like it so far. It provides me with the data that I need so far. I didn't have any issues getting it up an running.
#6 | |
Drives: '17 86
The Gunshine State
Drives: '14 BRZ Limited
I really wish the Torque app worked on iPhones, instead I just bought an old Android tablet and BT adapter and it's been working great. Check out the Torque app thread too.
![]() Current DD: M235i |
#9 | |
Drives: '17 86
When you disconnect & reconnect the wifi dongle, do you need to remove the wifi ip/gateway settings and re-configure in order for DashCommand to connect? I want to disconnect the device when I'm not in the car, but this happens to me and is pretty inconvenient. |
#10 | |
I haven't had that happen to me. I use one of these to turn the Dongle on/off. Not sure if thats why I haven't run into the issue. Although I would imagine switching it off would be the same as unplugging the dongle. What dongle are you using, I'm using this one |
#11 | |
Drives: '17 86
#12 | |
#13 | |
Drives: '17 86
Thanks for the info |
#14 |
Drives: 2016 Ablaze Scion FR-S
Hey all, just some personal consumer advice. I got a Foseal Wifi OBD2 reader from Amazon for my iPhone and no matter which app I used, it just wasn't working even though the reader itself was making blinky lights saying that it was communicating with the phone.
Then I used a friend's Veepeak, which slipped into the OB2 port like butter and immediately got it working on Car Doctor. So despite what other's experiences have been with Veepeak, that's the one that worked on my car. |
| OBD2 Port | RJ_ | AUSTRALIA | 33 | 08-25-2016 10:25 PM |
| OBD2 to phone app? | Jajanken86 | Software Tuning | 5 | 06-16-2016 02:27 PM |
| OBD2 for iPhone? | Venator | Software Tuning | 8 | 07-21-2014 02:41 PM |
| WTB: OBD2 splitter | 1Cor10:23 | Canada Classifieds | 0 | 04-07-2014 11:56 AM |
| OBD2.ca any good? | zyvod | CANADA | 11 | 08-28-2013 10:34 AM |
