Old 07-17-2014, 10:37 PM   #1
Venator
Venator's Avatar
Drives: Asphalt FR-S
OBD2 for iPhone?
I am not sure if this should be in this area but here goes. I would like to use Dash command for iPhone but don't know of any decent, inexpensive OBD2 dongles. Anyone here know of any?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 07-17-2014, 10:53 PM   #2
steve99
The cheap obd dongles are known as elm327 search for that on ebay can get them foe about 10 dollars. However they may not work with all software, they work with torque on android fine
FRSpappa (07-18-2014)
Old 07-17-2014, 11:12 PM   #3
jamesm
you'll need to use a bluetooth dongle. make sure you get a decent one or the refresh rate will be really slow.
The Following User Says Thank You to jamesm For This Useful Post:
Old 07-17-2014, 11:21 PM   #4
Venator
Venator's Avatar
Yea I have a 327 but my iPhone 5s won't pair with it... 😭
Old 07-19-2014, 12:25 AM   #5
Corradooo
Corradooo's Avatar
Drives: Storm trooper FRS
Do not get a Bluetooth dongle for your iPhone. Get an elm327 wifi adapter. You configure the settings of clk devices manually to 192.168.0.123 and subnet to 255.255.255.0 and set the dash command app setting to custom ip and 192.168.0.10 and tcp port to 35000 and you should connect. The car has to be on.
Corradooo is offline   Reply With Quote
The Following User Says Thank You to Corradooo For This Useful Post:
Venator (07-19-2014)
Old 07-19-2014, 12:54 AM   #6
Venator
Venator's Avatar
Yup this is what I am going with
Old 07-19-2014, 02:30 PM   #7
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
http://www.ebay.co.uk/itm/161310957223
I find this obd2 wifi for IPhone connects perfectly.
Ryan86 is offline   Reply With Quote
Old 07-19-2014, 09:43 PM   #8
Corradooo
Corradooo's Avatar
[ame="http://www.amazon.com/dp/B005M16GMI/ref=sr_ph?ie=UTF8&qid=1405820527&sr=1&keywords=elm +327"]Amazon.com: Wifi Obd2 Elm327 Car Code Reader for Iphone Ipod Touch Ipad: Automotive[/ame]
I've been using this with dash command on the iPad mini i mounted in my dash for like 4 months now using the method I described above.
Old 07-21-2014, 02:41 PM   #9
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
elm 327 wifi version. Bluetooth elm doesn't work with iphone unless you jail break it.
fantah is offline   Reply With Quote
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
Bluetooth OBD2 Adapter qbzee007 AFRICA 24 07-16-2015 08:57 AM
WTB: OBD2 splitter 1Cor10:23 Canada Classifieds 0 04-07-2014 11:56 AM
OBD2 Bluetooth Adapter Ravenlokk Engine, Exhaust, Transmission 49 09-04-2013 03:50 AM
OBD2.ca any good? zyvod CANADA 11 08-28-2013 10:34 AM
