Old 02-27-2017, 01:03 PM   #1
starstream
Drives: 2013 scion frs
rubbing noise
previously turning the wheel to the right it made a slight rubbing noise. Now when i hit 40 mph going straight it the noise starts.. and the faster i go the fast the rubbing is. it sounds like driving in the rivits on the side of the highway but not as loud but still pretty noisey... im assuming its a wheel bearing? if you think it is something else please tell me and if you are certian its a wheel bearing where can i find the cheapest one?
starstream is offline   Reply With Quote
Old 02-27-2017, 09:42 PM   #2
angadam
Drives: 14 BRZ Limited
Good possibility of bearing but check for choppy tires as well. They make a similar noise. If indeed the wheel bearing look at www.rockauto.com. I buy parts from them all the time and have never had a bad experience.
angadam is offline   Reply With Quote
RUBBING with 17x9 +35 Devil 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-25-2016 01:12 PM
Rubbing noise at ~70 degrees steering both ways 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-30-2015 08:13 PM
Rubbing noise on cold start only in reverse? brsaresmgs Issues | Warranty | Recalls / TSB 2 01-18-2015 07:15 PM
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
