Drives: Ultramarine FR-S
RUBBING with 17x9 +35
I'm running 17x9+35 TC105Ns with 245/40/17s and they're running pretty bad at -1.5 degrees of camber on my KONI struts. How much camber do you guys run with this wheel setup? I don't want to run wheel spacers at the track.
Killed Scion
Drives: 2013 FR-S Whiteout
How are you getting your camber? With bolts or with top plates?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
Drives: 2014 BRZ Sport-tech
Try maxing out positive camber with a camber bolt and get your negative camber through a top hat.
| The Following User Says Thank You to infinity21 For This Useful Post: | MisterSheep (04-22-2016) |
Drives: LR BRZ Limited
you're either too low or your alignment is off besides camber. toe and caster?
Any pics of where you're rubbing? I would just mark your areas where you're thinking you're rubbing with blue tape and drive around and find out where your tire is touching the blue tape. thats where you can determine you're rubbing. otherwise 17x9 +35 with 245s should not be rubbing. Its a pretty safe offset |
| The Following User Says Thank You to DuMa For This Useful Post: | Toyarzee (04-22-2016) |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
That's crazy... I'm running 17x9 et35, albeit rpf1's, and 1.8 neg camber without any issue on stock struts. Are the Koni's much different?
Drives: '13 SWP ZC6 R
More importantly, WHAT are you rubbing? Tire + strut? Tire + wheel arch? Tire + fender liner?
Please be more vague.
| The Following 3 Users Say Thank You to sdemo For This Useful Post: |
Drives: 2013 WRB BRZ
How much are you lowered? I'm lowered 1 inch on springs with the stock struts, same wheel/tire, same camber (SPC bolt in lower hole) and I don't rub anywhere.
| The Following User Says Thank You to BigTuna For This Useful Post: | MisterSheep (04-22-2016) |
Not a troll
I have -2.5* of camber up front on 17x9 +35 on stock struts and S-Tech springs. Camber was achieved by adjustable top hats (SilverProject) and camber bolts. I don't rub, and have a healthy amount of space between wheel/tire and spring/strut.
If I recall correctly, -1* is probably the safest amount to run up front without adjustable top hats. |
| The Following User Says Thank You to Cole For This Useful Post: | wparsons (04-25-2016) |
Drives: 2013 Firestorm FRS
#10 |
Drives: whiteout
i ran 255 with that wheel. you might need to shave the rear tabs other than that you should be good the rear fenders are rolled from the factory
#11 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Probably rubbing on the spring/shock considering he said he doesn't want to run spacers.
Surprising since I run 17x9 +45 on coils and nowhere near close.
#12 |
Drives: 2013 Raven FRS 6MT
i ran 17x9 +35 245/40/17 on stock suspension and no rubbing
#13 |
Literally none of you are helping.
| The Following User Says Thank You to sdemo For This Useful Post: | wparsons (04-25-2016) |
#14 |
Drives: 2015 Halo FR-S
| Endlinks rubbing | frs_94 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-16-2016 05:43 PM |
| Rubbing fender. | dito | Southern California | 34 | 05-15-2015 02:12 AM |
| Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? | Eazy-V | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 11-02-2014 10:42 PM |
| How much rubbing is too much rubbing? | Pokeguyjai | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 12-10-2013 09:04 PM |
| Rubbing sound? | Mo707 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-15-2013 12:06 PM |
