Old 02-21-2017, 12:03 AM   #1
Nightflo
Nightflo's Avatar
Technical Problem, JRSC 2015 BRZ
Ive got a question, I've tried to figure this out but i can't. My car ran good for about 5-6 months but all of a sudden started acting weird.
-Runs a little rich(13.4) on cruise
-Spikes too lean on WOT thus not delivering power
-on e85, does NOT turn on unless i baby it until it stays on
-on e85, runs way too lean on WOT and then corrects itself when rmps go past 3200.
what i have on it is
-Jackson Racing C38 supercharger
-JR dual radiator-oil cooler
-Crawford AOS
-Delicious Tuning Flex Fuel
-UEL header with Full Bolt ons
-DWs 300 Pump
-DWs 700cc Injectors
-Delicious MAP sensor
tried disassembling and reassembling fuel pump but still nothing
SOMEBODY PLEASE HELP
Nightflo is offline   Reply With Quote
Old 02-21-2017, 12:47 AM   #2
johan
Drives: '14 981CS, '99 NB1
bad primary o2 sensor and/or exhaust leak.
johan is offline   Reply With Quote
Old 02-21-2017, 12:51 AM   #3
Nightflo
Nightflo's Avatar
I can figure this out by checking the o2 sensor on live datalog to see if it flickers right? if it doesnt flicker(digit changing) then its a dead o2 sensor right?
Old 02-21-2017, 02:44 AM   #4
dj2020
I had similar symptoms of the car all of a sudden running lean on e85. My fuel trims went extremely positive trying to compensate and eventually threw a lean code. I have similar mods as you: JRSC, DT flex fuel kit, DW injectors and DW Map sensor. I initially thought it was an exhaust or intake leak somewhere but that checked out okay. I ended up sending an idle log to zach@delicioustuning and he determined my ethanol content analyzer (black box) had gone bad. We replaced it and we were good to go again. I would look into that as it's a pretty easy thing to rule out. Good luck!
dj2020 is offline   Reply With Quote
Old 02-21-2017, 05:00 PM   #5
Nightflo
Nightflo's Avatar
thank you! im going to try that
crawford, deatschwerks, delicious tuning, e85 flexfuel, jackson racing
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
The death of JRSC rotrex 350z Forced Induction 21 03-18-2017 12:15 AM
JRSC oil use xsnapshot Forced Induction 3 03-27-2016 10:22 PM
2015 frs (fit rear camera) problem sroby Electronics | Audio | NAV | Infotainment 2 01-20-2016 06:49 PM
Was looking at this set up. Will i have a problem fitting my 2015 RS1 ?? ChuckButta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-09-2015 01:43 PM
