Old 02-12-2017, 09:44 AM   #1
mcrane
mcrane's Avatar
Boost Issues on Stock Internals
Hey Guys,
I am venturing into the world of forced induction with my 86 (stock internals). Was hoping some of you could clear a few things up. I understand that boosting any car comes with more maintenance and better diligence. I will be upgrading the Clutch and Flywheel to a Stage 2. The vehicle will be used for daily driving and the occasional autocross. These questions are more directed toward the engine.
- Since the FA20 is high compression, wouldn't boost just increase heat and cause the stock internals to wear faster?
- I am aiming on 7 PSI. Is anyone running similar boost levels? If so, how many miles have you gone and have you had any major issues?
I guess the overall question is "how reliable is the stock FA20 at around 7-8 psi?"
- Thanks!
mcrane is offline   Reply With Quote
Old 02-12-2017, 02:07 PM   #2
FirestormFlex
Drives: 2015 Turbo FR-S
It's been shown to be quite reliable at reasonable power levels, especially if running E85 for fuel. But the problem in my experience is, 8psi gets boring and you very quickly want more.
FirestormFlex is offline   Reply With Quote
Old 02-12-2017, 02:16 PM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Save up money for a built block or spare engine! Do some research on the topic and you will find engines lasting seemingly forever and some that let go almost immediately. Tuning is a huge issue, but sometimes when everything is right the motor still goes. All depends!
Old 02-12-2017, 02:27 PM   #4
mcrane
mcrane's Avatar
Very true. Best not to even start. That way I don't get addicted to boost haha
Old 02-12-2017, 02:28 PM   #5
mcrane
mcrane's Avatar
Been there, done that. I have always felt that Forced Induction was a gamble. That comes from experience....
Old 02-12-2017, 02:34 PM   #6
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I have almost 55k miles on my turbo kit. I haven't had any issues with it, other than needing to replace the clutch. And I didn't even do that until 45k miles. I daily drive my car,a and have only tracked it once. I usually leave it at 8psi, but occasionally bump it to 12psi if I want to have a little fun. I have a flex fuel that I'll install in a month or 2 to have even more fun. Hope that helps.
kmbkk is offline   Reply With Quote
Old 02-12-2017, 02:50 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Well then why even ask the question with your experience, lol.
Old 02-12-2017, 08:02 PM   #8
mcrane
mcrane's Avatar
Because...clearly it wasn't good experience haha
Old 02-12-2017, 10:17 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
This one won't be either.
Old 02-12-2017, 10:38 PM   #10
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Do not my friends, become addicted to boost. It will take hold of you, and you will resent it's absence.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 02-13-2017, 01:24 PM   #11
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
My stock '13 motor lasted 3000 miles of daily abuse at 470hp (19psi w/ 5558). With how hard I beat on the car, I'm surprised it didn't blow up sooner.
Keep the car around 10psi with e85 (flex fuel), and it should last you a long time.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 02-14-2017, 09:19 AM   #12
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
We have customers on our turbo kit with over 30k miles, daily driven with some track time. Pump gas and E85, still on the stock motor.
Freddy@PTUNING is offline   Reply With Quote
Old 02-14-2017, 09:54 AM   #13
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
i usually run around 10-12 psi depending on weather with flexfuel as well. Been to several track events, only thing was clutch needed to be replaced, and the PSA of clamping your evap line otherwise it will pop off under boost. probably have over 10k miles boosted
pgranberg11 is offline   Reply With Quote
Old 02-14-2017, 10:14 AM   #14
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
#YOLO
Current DD: M235i
8RZ is offline   Reply With Quote
Safe amount of boost on stock engine? Octane Forced Induction 51 12-06-2017 07:25 PM
GReddy T620z Turbo Kit -- save $1500 over retail! 350 WHP on e85 STOCK INTERNALS ZeroTo86 Engine, Exhaust, Bolt-Ons 5 08-11-2016 09:36 PM
Fastest 1/4 mile on stock internals, 91-94 pumpgas, and street tires? hmong337 Tracking / Autocross / HPDE / Drifting 1 07-14-2015 02:25 PM
Electronic Boost Controller Issues 1BadFA20 Forced Induction 1 06-09-2014 01:21 AM
Scion Boost/Warranty Issues with Mods? Marusich Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 10-17-2013 12:26 AM
