Old 02-07-2017, 04:20 PM   #1
Eman
Drives: 2013 Scion FR-S 10 series
Custom one piece dash for double din
Ok so this is a continuation of an earlier post
http://www.ft86club.com/forums/showthread.php?t=114610
Where I customized my dash opening for a double din with bondo so that you didn't see the plastic dash kit. Not sure if this belongs here or in cosmetics but it revolves around the stereo so here goes.
Again, credit where credit is due, idea came from DigitalAssassin's build thread. I pulled the dash back out, recessed the stereo a little bit by drilling new mounting holes in the bracket and contoured the stereo opening to match the face of the head unit.
However, I also like the look of the one piece dashes so I joined the two sides of my dash trim with apoxy, added some bondo to smooth out the transition and wrapped it all in carbon fiber when I was done. I'm pretty happy with the way it turned out.
Eman
Eman is offline   Reply With Quote
The Following 4 Users Say Thank You to Eman For This Useful Post:
DAEMANO (02-07-2017), Griever423 (08-06-2020), Juzzotec (01-31-2019), Racecomp Engineering (01-29-2019)
Old 02-07-2017, 04:21 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Nice work, I don't like the CF look but the one-piece design is nice.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-07-2017, 04:30 PM   #3
Eman
Thank you. That's the beauty of vinyl wrapping, you can do it in pretty much any color or pattern you want. I figured since the stock piece had a CF finish I would stick with that.
Eman
Old 02-07-2017, 04:43 PM   #4
DAEMANO
Time Traveller
@Eman
Well done
The Following User Says Thank You to DAEMANO For This Useful Post:
Eman (02-07-2017)
Old 02-07-2017, 05:05 PM   #5
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
That does look good
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Eman (02-07-2017)
Old 06-08-2018, 01:41 PM   #6
Hayateki84
Drives: 2015 Scion FR-S RS 1.0 #384
Hey man do have the link to DigitalAssassin's walk through of this? I can't find it. I mean I appreciate yours but the more I can read the better
Hayateki84 is offline   Reply With Quote
Old 01-29-2019, 09:56 AM   #7
Taurant22
Drives: Toyota 86
Not bad dude. Looks interesting to me. I would like to add something for you 'Best Double Din Head Unit. This will make your journey more interesting.
Source: https://rocketcarparts.com/best-double-din-head-unit/
Taurant22 is offline   Reply With Quote
Old 01-29-2019, 09:59 AM   #8
StraightOuttaCanadaEh
Wes
new ones come with a one piece dash. Do they not fit on the '13-'16s?
Instagram: @gt86ws
Old 01-29-2019, 10:33 AM   #9
We just want something with a standard double din opening.
A one piece dash with a double din would sell a million copies tomorrow.
- andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Chimera (01-29-2019), tehShirt (01-29-2019)
Old 01-29-2019, 12:09 PM   #10
Wes
- andrew
sorry, what's a double din?
EDIT: nevermind, I googled it and it's the head unit
Instagram: @gt86ws
Old 01-29-2019, 12:26 PM   #11
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
They fit perfectly! I swapped out my '15 FRS dash with a 2017 86 dash.
@OP, the one-piece dash looks so much better IMO!
eastendraceshop is offline   Reply With Quote
Old 01-31-2019, 03:49 AM   #12
Juzzotec
Juzzotec's Avatar
Drives: Toyota 86 GTS
That looks great man, can I ask how you knew the two pieces were lined up perfectly when you were gluing them together? Did you just lay them on a flat surface side by side?
Juzzotec is offline   Reply With Quote
Old 08-05-2020, 12:18 AM   #13
Chosen86
Drives: 2014 FR-S
Eman
The stock piece isn’t actually supposed to look like CF. It’s a pattern the designers came up with using the vintage triangular Toyota emblem (same motif around window switches, climate controls and the brake light’s shape).
Chosen86 is offline   Reply With Quote
Custom dash for double din stereo. Eman Electronics | Audio | NAV | Infotainment 3 01-16-2017 11:55 PM
WTB BRZ Double Din Dash Pieces mikeTee Want-To-Buy Requests 4 05-05-2016 01:33 AM
Double Din dash trim jinyang1590 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-17-2015 02:57 PM
* M Technica Aero Wheels / Two Piece and Three Piece Custom Wheels * GuerillaRacing Wheels and Tires 110 02-25-2015 06:10 PM
Idea to fix double din dash piece Larkin Cosmetic Modification (Interior/Exterior/Lighting) 0 06-22-2013 02:16 AM
